electrical interior problems on 2000TL
Old Jan 17, 2006 | 12:37 PM
kidfried's Avatar
kidfried
Default electrical interior problems on 2000TL
Purchased new, love my vehicle. Interior sensor lights on the fritz- emergency brake sensor light sticks sometimes, clock light is out, side airbag light sometimes comes on, a few other minor luminescents have gone out.
Any recommendations for economic reliable repair?
Old Jan 19, 2006 | 04:39 PM
VPUPPY's Avatar
VPUPPY
Sounds like you have other issues. The brake light on dash comes on for two reasons - low brake fluid and ebrake up. So check the brake fluid level. I suggest you have a shop scan the srs system for codes. Also, the clock light may just be a bulb. If none of these are true, you may have electrical issue. Just some suggestions before you have the electrical system checked out.
Old Jan 20, 2006 | 11:23 AM
kidfried's Avatar
kidfried
You sir are correct.
I had low brake fluid, thus the brake sensor light.
Clock light was a bulb and the side airbag light is apparently a common thing on this vehicle if weight is detected on the seat (or so John at Curry Acura service said).
Thank you for your response.
Old Jan 20, 2006 | 05:55 PM
VPUPPY's Avatar
VPUPPY
No problem. Glad you got these issues sorted out.
