O2 sensor removal...
Old Dec 3, 2005 | 11:07 AM
Bigme574's Avatar
Bigme574
Default O2 sensor removal...
On my 1998 Acura TL, I threw an O2 sensor code. So, aside from being able to determine which sensor it is...I dont know where the connector is OR how the hell to get the one off on the maniufold...any ideas???
THanks
Aaron
Old Dec 3, 2005 | 12:08 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
there are a few different codes for the O2 sensors, each code will tell you which sensor it is.
To get to the sensors, you need to get under the car... you'll find the connector by tracing the wire, it will be within a few inches of the sensor. The sensor itself is just screwed into the pipe, usually an open end wrench will work fine to loosen it.
