97 2.5TL Exhaust Noise
Old Sep 23, 2005 | 03:40 AM
TexasHonda's Avatar
TexasHonda
Default 97 2.5TL Exhaust Noise
On startup and idle, I detect a sound from the exhaust manifold area that sounds like an exhaust leak. I've looked and felt (cold engine) for a leak w/o success. I removed the upper heat shield and inspected w/ a mirror for cracks and found nothing.
I'm wondering if maybe this sound is "typical" for the 2.5. It seems a little noisy for a luxury car. Anyone else note this exhaust sound on a 2.5L engine?
I recently purchased the car and don't have much experience w/ it yet.
Thanks
Old Sep 23, 2005 | 08:25 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
If there is a leak, you will eventually see it because the leak area will probably be darker, unless your engine is filthy dirty and can't tell. Sometimes, it could be just a worn exhaust manifold gasket.
Old Oct 21, 2005 | 09:13 AM
mdazb's Avatar
mdazb
Testing
Old Oct 21, 2005 | 09:16 AM
mdazb's Avatar
mdazb
Hello, first time here.....
I just pulled my exhaust manifold. (mine has the same sound) Found a crack in the middle pipe by the collector. Acura wants $1,000.00 and change for a new one. Going to see if I can get it welded.
Old Oct 21, 2005 | 06:47 PM
ACURAmechanic's Avatar
ACURAmechanic
If your car is a '96 or '97 with less than 150k miles Acura will warranty it.
Old Oct 21, 2005 | 08:53 PM
mdazb's Avatar
mdazb
It is a '96 with 96,000 miles. How would I go about getting it warrantied?
Old Oct 22, 2005 | 06:35 AM
ACURAmechanic
Put it back together and make an appointment with your dealer.
just tell them that the engine has an exhaust leak , and they shouldn't give you any problems.
If you give me your VIN I will check to make shure it is covered.
Old Oct 22, 2005 | 10:23 AM
mdazb's Avatar
mdazb
That would be great if you could do that.
Thanks
Old Oct 24, 2005 | 04:33 PM
mdazb's Avatar
mdazb
Going to the dealer Thursday for warranty repair . Thanks ACURAmechanic for the info. If you were close I'd buy ya a cold one:cheers: .
Old Oct 27, 2005 | 09:12 PM
mdazb's Avatar
mdazb
Update......
Got my TL back from the dealer. They replaced the exhaust manifold assy., did a complete tune up complete with wires and all coils. Replaced the dist. all under warranty. Got my power back with no noise:goodjob:
