93 vigor ac problem
Old May 24, 2005 | 11:13 AM
RIMAS's Avatar
RIMAS
Default 93 vigor ac problem
my ac was working fine and then a few days ago it just stopped, it doesnt even turn on or blow air in through the vents.
im thinkin it might be a fuse problem but i checked the fuse on the inside of the car under the steering console and it checks out but it still doesnt work, does anyone know which fuse under the hood controls the fuse box in the car? oh my freon is all good, this mechanic was saying that it needs to be converted over to the new style which is not neccassarily true, but any advice would be appreciated.....thanks fellas
Old May 27, 2005 | 08:27 PM
greenphant's Avatar
greenphant
93 Vigor GS
The same thing recently happened to my Vigor. There is an electrical box to the right of the passenger front kick panel which houses some stuff for the blower. I can get you the wiring diagram if you want. I replaced one of those and now it works like a champ. I found the part at a local junkyard since the dealer would have to special order it.
