Vigor wont start
Old Mar 23, 2005 | 09:57 PM
littlealk4's Avatar
littlealk4
Default Vigor wont start
Ok I have a 93 Vigor. Never had any signs of trouble. Well one day Im driving and it sputters out and dies. So I push it home...as it will not start. I pull the plug wires and notice the VC gasket is leaking around the plugs...covering the plugs in oil. I change the VC, the plugs and the wires...the car stars right up and runs for about 5 mins. Then it proceeds to sputter and die like before. Now it wont start. There is no oil onthe plugs or wires anymore....And I checked fuel and spark (orange spark). Now I am at a loss. Any of you guys have ideas?
Old Mar 23, 2005 | 10:41 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
If VC you mean valve cover, and you found oil covering the plugs, then I believe that's something major. Any other signs? Like leaking fluid around the head gasket? Something like this, you better have a mechanic to pull off the valve cover and check for you.
Old Mar 24, 2005 | 01:04 PM
Vigor's Avatar
Vigor
The oil in the plugwells is a common problem. It's the spark plug o-rings. Did you change these with the valve cover gasket?
Try starting it again...if it starts cold but dies hot we can diagnose it. If it's just not starting at all that's a whole 'nother troubleshooting route.
Old Mar 25, 2005 | 11:31 AM
littlealk4's Avatar
littlealk4
Yeah I replaced these O-rings. It will not start at all...
Old Mar 28, 2005 | 08:55 AM
Vigor's Avatar
Vigor
Is it cranking over, but not starting?
How many miles are on the car, and have you checked your timing belt?
Old Apr 5, 2005 | 11:51 AM
luky1380's Avatar
luky1380
ck compression and orange spark is no good it have to be blue
prob. needs coil and ck distributor for internal leak
