ALLDATA - TL Auto Recalls & Tech Service Bulletins
Found this link, interesting
http://www.alldata.com/TSB/01/00010926.htmlhttp://www.alldata.com/TSB/01/00010926.html
heres the list
Bulletins for 2000 Acura TL V6-3206cc 3.2L SOHC MFI
Safety Recalls
TSB Number Issue Date TSB Title 02-010 APR 02 Recall - Passenger Air Bag Replacement
01-030 AUG 01 Recall - Front Seat Belt Buckle Replacement
00-020 JUN 00 Recall - SRS/Seat Belt Indicator ON
General Recalls
TSB Number Issue Date TSB Title 03-017 SEP 03 Campaign - PCM/Fuel Pressure Regulator Update
02-027 SEP 03 Campaign - Automatic Transmission Defect
Service Bulletins
TSB Number Issue Date TSB Title 04-008 MAR 04 Navigation System - Operational Malfunctions
01-041 FEB 04 Engine - V6 Engine Oil Leaks
04-004 FEB 04 Computers/Controls - HIM Module Updating
01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
03-029 OCT 03 Brakes - Brake System Lamp Comes ON/Goes Off
03-028 OCT 03 Navigation System - Incorrectly Displays Phone Numbers
91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
02-015 JUL 02 Air Bag System - SRS Lamp ON/DTC's Set
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
02-006 MAR 02 Front Seat Back Panel - Loose/Detached
02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
96-025 DEC 01 Navigation System - Component Exchange Program
99-041 NOV 01 Navigation System/A/C - Operation/Testing
01-016 SEP 01 PCM - MIL ON/DTC P0128 or P1486 Stored
99-051 AUG 01 Exhaust - Muffler Paint Peeling
00-037 AUG 01 Brake Disc - Refinishing Guidelines
01-004 JUL 01 Wipers - Smear or Streak the Windshield
01-011 FEB 01 Radiator/Condenser Fan - Runs Continuously
01-003 JAN 01 Alarm System - Sounds By Itself Intermittently
01-001 JAN 01 PCM/Fuel Pressure Regulator - Hard Starting
00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
00-032 NOV 00 Moonroof - Squeaks from Moonroof Seal
00-025 AUG 00 Body - Windshield Molding Deformed
87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
00-018 JUN 00 Door Switch - Squeaks
00-016 MAY 00 Door Mirror - Vibration
00-015 APR 00 Accessory Moonroof Visor - Creaking Noise
00-014 APR 00 Squeek or Creak From Driver's Seat
00-008 MAR 00 Torque Converter Oil Seal Installation Tool
98-037 FEB 00 Brakes/Traction Control - ABS/TCS Lamp ON/DTC's Set
99-041 FEB 00 TQI OF THE DVD NAVIGATION SYSTEM
00-002 FEB 00 Rear Door Sash Trim is Wrinkled
98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
99-040 OCT 99 Troubleshooting DTC P1456 and P1457
99-043 SEP 99 TQI Information (2000 3.2 TL)
96-025 SEP 99 Navigation System Exchange Program
90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
98-004 APR 98 Audio Unit Anti-Theft Labels
98-005 APR 98 CV Joint Boots - New Band & Tool
92036 NOV 92 Vehicle Fails State Inspection Emissions Test
heres the list
Safety Recalls
General Recalls
Service Bulletins
