'96 TL keyless entry programming
Old Jan 14, 2005 | 02:09 PM
rick1980's Avatar
rick1980
Default '96 TL keyless entry programming
Does anybody have the instructions for '96 acura tl keyless entry programming? I bought a remote on ebay and noone there has them.
rick
Old Jan 16, 2005 | 08:50 AM
seaninator's Avatar
seaninator
I have the same problem with my 97 I will let you know if I figure it out.
Old Jan 16, 2005 | 09:57 AM
seaninator's Avatar
seaninator
Search by civicpete. His instructions worked for my CL
Old Jan 19, 2005 | 11:30 AM
WeavzCL's Avatar
WeavzCL
I just got an 03 CL Type-S, but I didn't get the keyless entry remote. How do I determine which remote I need (you know, FCC Number?) And then how do I program it, once I do get it?
Old Jan 19, 2005 | 09:36 PM
ACURAmechanic's Avatar
ACURAmechanic
Sit in driver's seat with doors shut. Turn ignition key to run (do not start)press a button on remote ,turn ignition off. Repeat process 3 times. When you press the remote on the last (4th) time the locks will cycle, indicating you are in programming mode. Then press any button on the remotes you want to program. The locks should cycle after each remote. Turn ignition off.
Old Jan 21, 2005 | 09:36 AM
WeavzCL's Avatar
WeavzCL
What about the FCC ID number of the remote, is the only way to figure that out to call my dealership?
