environmental/pollen filter ?
Old Dec 16, 2004 | 01:23 PM
jbuffettph's Avatar
jbuffettph
Default environmental/pollen filter ?
I want to replace the pollen filter on my 2001 CL I have the OEM filters and learned from this board that they are behind the glove box. I removed the clips which give me access to behind the glove box I just can't figure out how to get to the filters. There is a solid plastic piece with perforations that says do not discard that is molded into the back of the plate behind the glove box.
Do I access these from another place?
Thanks
Old Dec 16, 2004 | 06:15 PM
jbuffettph's Avatar
jbuffettph
it would appear that at least one side of that plastic must be cut in order to access the filter any thoughts?
Old Dec 19, 2004 | 07:39 PM
jbuffettph's Avatar
jbuffettph
Well I can't believe i'm the only one to have this problem.
Friday I went off to the Acura dealer and they copied the page from the service manual for me. I am really impressed with them as they have a whole different feel than what I'm used to at my Toyota dealer. I don't feel like I have to be counting my fingers when I shake their hand as I have in the past.
You do have to cut that panel iwth a wire cutter or a snip and then reuse it turning it 90 degrees after putting in the new filters. I knew they never had been changed because the only ay to do it is to cut through the plastic and I had to do that.
Wow were those dirty after 76,000 miles I even took a vacum to the area as there was debris in there. The manual says to have it done every 15-30K
Old Dec 19, 2004 | 10:41 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
If you can, scan the pages and post them here so other members can view them.
Old Dec 20, 2004 | 10:48 AM
jbuffettph's Avatar
jbuffettph
Default great idea
Great idea,
I don't have a scanner but i will find someone who does.
