The 20004 Tl
Old Sep 1, 2004 | 05:33 PM
pillz's Avatar
pillz
DoughBoy
Default The 20004 Tl
Im comparing the 2004 Acura TL to some other cars. and it says that the TL has a single over head cam. is this true?
I just went to the acura website. and it is true. the TL does use a SOHC. do u kno why they would do this over a DOHC? wasnt the 2001-20003 DOHC?
Old Sep 2, 2004 | 03:57 AM
flyromeo3's Avatar
flyromeo3
well since its a V 6 there is one came on either side of the V
One cam works on the I/E side and the other cam does the same for the other 3 cylinders.
all in all there is one cam per 3 cyl.
Old Sep 2, 2004 | 10:09 AM
shivers's Avatar
shivers
Moderator Alumni
Accords, TLs, CLs, Pilots, MDXs, etc. are all SOHC (2 cams, one per side). The only DOHC (4 cams, 2 per side) Honda V6 is in the NSX.
2005 s2000
Old Sep 2, 2004 | 02:59 PM
AcuraFanatic's Avatar
AcuraFanatic
DOHC's can generally handle higher revolutions better because they're closer to the valves.
They also tend to be noiser in operation, which you don't want for a luxury-isque vehicle.
