Three mods I want!
1st I wannna say hello everyone.
Ok, after searching a bunch of websites for rims, I came up with a few questions about aftermarket wheel fitments. I have a 04 tl 6 spd. The brembo in the front are very close to the rim insides. I heard a +45 offset is on the accessory wheel. However in the rear, there is more room to play with. I also read we can dip down to a +35 offset on the car (I would only do this in the rear for brake clearance issues) I want to go with a 9 1/2 wheek with a 265/30/19 ( extremly close to stock diameter) with the said offset it will only be 8mm closer to the inside housing and 24 or 28 mm closer to the fender.
Any problems you guys see with this?
2nd mod is 6000k bulbs for stock hid and a hid kit for fogs...will i have a problem with the bi-xenon operation? or is it just a shutter in the housing that is moving regardless of bulb?
Help is appeciated. Sorry for any misspellings i was rushing.
*edit* i forgot the 3rd mod. Exhaust. i only want bolt ons from the split back. i want a more substantial look. i also want it to fit the cut out nicly with only a small gain in noise.
Those tires should be able to fit your TL without any problems if the specifications that you listed are indeed correct.
As for the Xenons, I wouldn't mess with those unless you truly know what you're doing.
For exhaust, Comptech has been historically known for making nice exhaust systems that sport a low rumble. I don't know if they've come out with an exhaust for the '04 models yet.
Good luck.
Good luck.
