2010 Acura ZDX - Specifications
TORRANCE, Calif. - Aug 16 — POWERTRAIN Engine Type 3.7-liter, SOHC, VTEC® V-6 Displacement 3664 cc Horsepower, SAE net 300 hp at 6,300 rpm Torque, SAE net 270 lb-ft at 4,500 rpm Valvetrain 24-valve Variable Valve Timing and Lift Electronic Control (VTEC®) Compression Ratio 11.2:1 Redline 6,800 rpm Induction System PGM-FI multi-point fuel injection Ignition System Electronic direct ignition system Throttle Drive-By-Wire? throttle system Emission Certification EPA TIER 2 ? BIN 5 and CARB LEV II ULEV standards Bore and Stroke 3.54 x 3.78 inches (90 x 96 mm) Engine Block Die-cast lightweight aluminum alloy Alternator 12V-130 Amperes Battery 12V-65AH (550 Cold Cranking Amps) Required Fuel Premium Unleaded Layout Transverse-mounted, front-engine Drivetrain Super Handling All-Wheel Drive? (SH-AWD®) Transmission 6-speed automatic with Sequential SportShift and Grade Logic Control Gear Ratios:1 Drive Gear
First
Second
Third
Fourth
Fifth
Sixth
Reverse
Final Transmission
3.359
2.095
1.485
1.065
0.754
0.556
2.269
4.250 Final Drive
14.277
8.903
6.311
4.527
3.207
2.361
9.645
CHASSIS Base and Technology Package Advance Package Body Type Unit-body design Front Suspension Fully independent suspension with MacPherson struts Rear Suspension Multi-link independent suspension with trailing arms Shock Absorbers Monotube dampers with internal blow-off valve Magneto-Rheological monotube dampers Stabilizer Bars Front Rear 24.0 mm (solid) 26.5 mm (hollow) 24.0 mm diameter (solid) 27.2 mm diameter (hollow) Steering Type Variable power-assist rack-and-pinion Speed sensitive, variable power-assist rack-and-pinion Steering Ratio 17.0:1 17.6:1 Steering Wheel Turns (lock-to-lock) 3.41 Turning Circle (curb-to-curb) 38.4 feet (5.86 meters) Braking System 4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist Front Brakes 13.0-inch (330 mm) diameter ventilated rotors; dual-piston cast-iron brake calipers Rear Discs 13.2-inch (334 mm) diameter solid disc rotors; single-piston cast-iron brake calipers Wheels 19x8.5-inch cast-aluminum wheels Tires Michelin Latitude P255/50R19 103H M+S all-season Spare wheel/tire 17x4-inch steel wheel with T165/80D17 tire Stability Control Vehicle Stability Assist? (VSA®) with Traction Control System (TCS) CAPACITIES Cooling System 2.4 gallons 9.2 liters Fuel Tank 21.0 gallons 79.5 liters Engine Oil
Oil change w/filter: 4.5 quarts
Total oil volume: 5.3 quarts Oil change w/filter: 4.3 liters
Total oil volume 5.0 liters Interior Volumes EPA passenger volume 91.2 cu ft
Max cargo with rear seats up 26.3 cu ft
Max cargo with rear seats down 55.8 cu ft FUEL ECONOMY EPA Fuel Mileage 16/22/18 mpg (city/highway/combined) EXTERIOR DIMENSIONS Wheelbase 108.3 in (2750 mm) Track, front 67.7 in (1720 mm) Track, rear 67.7 in (1719 mm) Overall Length 192.4 in (4887 mm) Overall Width 78.5 in 85.6 in 1993 mm (at doors) 2174 mm (at mirrors) Overall Height 62.8 in 61.3 in (1596 mm) ? unladen (1557 mm) ? fully loaded Ground Clearance 7.9 in 6.5 in (200 mm) ? unladen (164 mm) ? fully loaded Approach/Departure Angle Approach ? 19.8 degrees Departure ? 23.2 degrees Breakover ? 16.9 degrees TOWING Maximum Towing Capacity 1,500 lbs (680 kg) WEIGHTS Curb Weight ZDX ZDX with Technology Package ZDX with Advance Package 4,424 lbs (2006.8 kg) 4,431 lbs (2009.9 kg) 4,462 lbs (2023.8 kg) Weight Distribution % front/rear 57.7/42.3 INTERIOR DIMENSIONS Front Head Room 38.0 in (966 mm)
Leg Room 42.6 in (1083 mm)
Hip Room 57.3 in (1456 mm)
Shoulder Room 59.7 in (1516 mm) Second Row Head Room 35.3 in (896 mm)
Leg Room 31.1 in (790 mm)
Hip Room 55.3 in (1404 mm)
Shoulder Room 55.4 in (1406 mm) WARRANTY Vehicle 4-year / 50,000-mile limited warranty Powertrain 6-year / 70,000-mile limited warranty Outer Body Rust-Through 5-year / Unlimited-mile limited warranty
More...
First
Second
Third
Fourth
Fifth
Sixth
Reverse
Final Transmission
3.359
2.095
1.485
1.065
0.754
0.556
2.269
4.250 Final Drive
14.277
8.903
6.311
4.527
3.207
2.361
9.645
More...
