2010 Acura RDX Specifications
TORRANCE, Calif. - Jul 28 — POWERTRAIN Engine Type Turbocharged 2.3-liter, 16-valve, DOHC i-VTEC® inline 4-cylinder Horsepower, SAE net 240 hp at 6000 rpm Torque, SAE net 260 lb-ft at 4500 rpm Redline 6800 rpm Bore and Stroke 3.4 x 3.9 inches (86 x 99 mm) Displacement 2300 cc Compression Ratio 8.8:1 Maximum turbocharger boost pressure 13.5 psi Induction System Multi-Point Fuel Injection Valvetrain intelligent Variable Valve Timing and Lift Electronic Control(i-VTEC®), 4 valves per cylinder, DOHC Engine Block Die-cast lightweight aluminum alloy Emission Certification EPA TIER 2 – BIN 5 and CARB LEV II ULEV Throttle Drive-By-Wire Throttle System™ Ignition System Direct ignition system with knock control Alternator 12V-105AH Battery 12V-65AH Recommended Fuel Premium Unleaded Layout Transversely mounted, front-engine Drivetrain Front Wheel Drive (RDX 2WD)
Super Handling All-Wheel Drive™ (RDX SH-AWD™) Transmission Sequential SportShift 5-speed automatic with F1®-style paddle shifters and Grade Logic Control Ratios (:1) RDX (2WD)
First 2.697
Second 1.606
Third 1.071
Fourth 0.694
Fifth 0.538
Reverse 1.889
Final 4.312 RDX (SH-AWD™)
First 2.697
Second 1.606
Third 1.071
Fourth 0.766
Fifth 0.612
Reverse 1.889
Final 4.533 CHASSIS Body Type All-steel unit body Front Suspension Fully independent front suspension with MacPherson struts and stabilizer bar Rear Suspension Independent multi-link rear suspension with stabilizer bar Shock Absorbers Front and rear twin tubes Stabilizer Bars: RDX (2WD) 21 mm diameter, solid (front)19 mm diameter, solid (rear) Stabilizer Bars: RDX (SH-AWD™) 21 mm diameter, solid (front)19 mm diameter, solid (rear) Steering Type Torque-sensing variable power-assisted, rack-and-pinion Steering Ratio 15.1:1 Steering Wheel Turns (lock to lock) 2.76 Turning Circle (curb to curb) 39.2 feet (11.9 meters) Wheels 18x5-inch cast aluminum alloy wheels Tires Michelin Pilot HX MXM4 P235/55R18 all-season Braking System 4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist Front Breaks 11.7-inch (296 mm) diameter ventilated disc with dual-piston calipers Rear Breaks 12.0-inch (305 mm) diameter solid disc with single-piston calipers Stability Control Vehicle Stability Assist™ (VSA®) with Traction Control System (TCS) CAPACITIES Cooling System (total) 2.4 gallons/9.1 liters Fuel tank 18 gallons/68.0 liters Engine Oil Change w/ oil Filter- 4.97 quarts/4.7 liters
Total - 6.13 quarts/5.8 liters FUEL ECONOMY
EPA Fuel Mileage (City/Highway) 17/22 mpg (2WD)/17/22 mpg* (SH-AWD™)
*Based on 2008 EPA mileage estimates, reflecting new EPA fuel economy methods beginning with 2008 models. Use for comparison purposes only. Do not compare to models before 2008. Your actual mileage will vary depending on how you drive and maintain your vehicle. EXTERIOR DIMENSIONS Wheelbase 104.3 in (2650 mm) Track, front 61.9 in (1572 mm) Track, rear 62.6 in (1590 mm) Overall Length 180.7 in (4590 mm) Overall Width 73.6 in (1869.4 mm) Overall Height 65.2 in (1656.1 mm) Ground Clearance 5.12 in (130 mm) No load 6.3 in (159mm) Full Load 5.1 (130mm) Approach/Departure Angle Approach - 28.0 degrees
Departure - 22.0 degrees
Breakover - 18.5 degrees WEIGHTS Curb Weight RDX (2WD)
RDX (2WD) Tech Package
RDX (SH-AWD?)
RDX (SH-AWD?) Tech Package 3743 lbs (1698 kg)
3752 lbs (1702 kg)
3931 lbs (1783 kg)
3942 lbs (1788 kg) Weight Distribution (% front/rear) RDX (2WD)
RDX (SH-AWD?)
RDX (SH-AWD?) Tech Package 59/41
59/41
57/43
57/43 TOWING Maximum Towing Capacity 1500 lbs INTERIOR DIMENSIONS Front Head Room 38.7 in(982 mm)
Leg Room 41.8 in (1062 mm)
Hip Room 54.4 in (1383 mm)
Shoulder Room 58.2 in (1479 mm) 2nd Row Head Room 38.3 in (972 mm)
Leg Room 37.7 in (954 mm)
Hip Room 53.0 in (1347 mm)
Shoulder Room 56.3 in (1430 mm) Interior Volumes EPA Passenger Volume 101.4 cubic feet
Cargo area (rear seats up) 27.8 cubic feet
Cargo area (rear seats down) 60.6 cubic feet WARRANTY Vehicle 4-year/ 50,000-mile limited warranty Powertrain 6-year / 70,000-mile limited warranty Outer Body Rust-Through 5-year / unlimited-mile limited warranty
More...
First 2.697
Second 1.606
Third 1.071
Fourth 0.694
Fifth 0.538
Reverse 1.889
First 2.697
Second 1.606
Third 1.071
Fourth 0.766
Fifth 0.612
Reverse 1.889
RDX (SH-AWD?)
3752 lbs (1702 kg)
3931 lbs (1783 kg)
RDX (SH-AWD?)
59/41
57/43
More...
