EDO Competition tweaks Ferrari Enzo to 700 hp
Filed under: Aftermarket, Tuners, Supercars, Ferrari
Click above for a high-res gallery of the Edo Competition Ferrari Enzo.
Edo Competition has no qualms about taking positively perfect exotic machinery and tweaking it to suit customer's tastes. And when it comes to the paragon of rolling automotive masterworks, the Ferrari Enzo is arguably King of the Hill.
While the Enzo isn't lacking in either the power or appearance department, that hasn't stopped Edo from making some subtle changes to the Enzo's exterior and powertrain. Edo began by replacing the intake with a revised ram-air system and a set of high-flow air filters, then worked its magic downstream with a set of headers similar to those in the FXX, along with a duo of high-flowing cats and a new exhaust system with remote-controlled, butterfly valves that allow the sound levels to be adjusted on the fly. All those bits are tuned through a modified ECU to produce 700 hp and 527 lb.-ft. of torque, which is sent through a heavy-duty clutch and on down to a retuned stock transmission that replicates the shift times of the FXX.
The Enzo's factory rolling stock has been replaced with 19x10-inch wheels in front and 20x13-inch wheels in the rear, wrapped in Michelin tires sized 265/35 R19 and 335/30 R20, respectively. The wheels can be custom painted to the customer's specs and a new suspension package, with adjustable compression and rebound, has been developed to mimic the setup found on the FIA GT MC12.
Edo claims that the sprint from 0 to 62 mph is estimated at 3.5 seconds and that the run from rest to 186 mph is dropped to 22 seconds flat. All the specs are available in the press release after the jump.
Gallery: Ferrari Enzo by Edo Competition
[Source: Edo Competition via WCF]Continue reading EDO Competition tweaks Ferrari Enzo to 700 hp
Permalink | Email this | Comments
</img>
</img>
</img>
More...
More...
