Audi A3 TDI Clubsport Quattro concept
Apathy Kills
Filed under: Concept Cars, Hatchbacks, Audi
Click above for a high-res gallery of the Audi A3 TDI Clubsport Quattro.
Audi has released the first official images of its newest concept before the wraps are taken off at the Lake Wörther Tour in Austria later this month. Think of the Audi A3 TDI Clubsport Quattro concept as a smaller, racier, more attainable version of the Audi R8 V12 TDI concept shown in Detroit, with power provided by the highest specific output diesel in the world.
Look past the DTM-inspired bodywork and you'll get an aluminum-enhanced glimpse of the oilburning jewel that lies beneath. The 1,968cc turbodiesel produces 221 hp and 332 lb.-ft. of torque available at an oh-so-low 1,750 rpm. Power is sent through a six-speed manual transmission before it reaches the ground through Audi's quattro all-wheel-drive system. Audi claims that the A3 TDI Clubsport Quattro can reach 62 mph in 6.6 seconds and on to a top speed of 149 mph. We believe it.
While the body work might be a bit over the top, the tuned A3 sits 26mm lower than stock and rides on 20-inch wheels that fit cleanly into blistered wheel arches, widening the A3's track by 33 mm in front and 46 mm in the rear. Stopping power in the front is provided by six piston calipers clamping 356mm carbon ceramic discs, while standard steel brakes are fitted out back. Inside, it's all business with a bit of show car flare, including a flat-bottom steering wheel, bolstered buckets, aluminum trim, toggle switches and a red starter button to get the party underway. Audi has also fitted the concept with a its Drive Select system, which can change throttle response, exhaust sound, power steering assist, ESP settings and magnetic ride damping on the fly.
Audi isn't saying that the A3 TDI Clubsport Quattro is destined for production, but it would make an excellent runabout for the times when rolling the R8 V12 TDI to the store would be overkill.
Make the jump for the full press release.
Gallery: Audi A3 TDI Clubsport Quattro concept
Continue reading Audi A3 TDI Clubsport Quattro concept
Permalink | Email this | Comments
</img>
</img> </img>
More...
</img>
</img> </img>
More...
