Automotive News & Rumors Highlighting the latest in what's happening in and around the automotive industry.
Acura Automobiles: 2015 Acura RDX Specifications
Old Apr 2, 2014 | 06:40 AM
94civicEX's Avatar
94civicEX
I got worms.
Default Acura Automobiles: 2015 Acura RDX Specifications
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 5"]POWERTRAIN
[/TD]
[/TR]
[TR]
[TD] Engine Type
[/TD]
[TD="colspan: 4"] 3.5-liter SOHC V-6
[/TD]
[/TR]
[TR]
[TD] Horsepower, SAE net
[/TD]
[TD="colspan: 4"] 273 hp at 6,200 rpm
[/TD]
[/TR]
[TR]
[TD] Torque, SAE net
[/TD]
[TD="colspan: 4"] 251 lb-ft at 5,000 rpm
[/TD]
[/TR]
[TR]
[TD] Redline
[/TD]
[TD="colspan: 4"] 6,800 rpm
[/TD]
[/TR]
[TR]
[TD] Bore and Stroke
[/TD]
[TD="colspan: 4"] 3.5 x 3.7 inches (89 x 93 mm)
[/TD]
[/TR]
[TR]
[TD] Displacement
[/TD]
[TD="colspan: 4"] 211.8 cu in (3,471 cc)
[/TD]
[/TR]
[TR]
[TD] Compression Ratio
[/TD]
[TD="colspan: 4"] 10.5:1
[/TD]
[/TR]
[TR]
[TD] Induction System
[/TD]
[TD="colspan: 4"] Multi-Point Fuel Injection, Drive-By-Wire™ throttle system, Variable Cylinder Management (VCM)
[/TD]
[/TR]
[TR]
[TD] Valvetrain
[/TD]
[TD="colspan: 4"] Variable Valve Timing and Lift Electronic Control (VTEC®), 4- valves-per-cylinder, belt-driven, single overhead camshaft (SOHC)
[/TD]
[/TR]
[TR]
[TD] Engine Block
[/TD]
[TD="colspan: 4"] Aluminum block with cast-iron cylinder liners
[/TD]
[/TR]
[TR]
[TD] Emissions Certification
[/TD]
[TD="colspan: 4"] EPA TIER 2 – BIN 5 and CARB LEV II ULEV
[/TD]
[/TR]
[TR]
[TD] Ignition System
[/TD]
[TD="colspan: 4"] Direct ignition system with knock control
[/TD]
[/TR]
[TR]
[TD] Alternator / Battery
[/TD]
[TD="colspan: 4"] 12 volt – 130 amp / 12V-72AH
[/TD]
[/TR]
[TR]
[TD] Recommended Fuel
[/TD]
[TD="colspan: 4"] Premium Unleaded
[/TD]
[/TR]
[TR]
[TD] Engine Layout
[/TD]
[TD="colspan: 4"] Transversely mounted, front-engine
[/TD]
[/TR]
[TR]
[TD] Drivetrain
[/TD]
[TD="colspan: 4"] Front Wheel Drive (RDX)
All Wheel Drive with Intelligent Control (RDX AWD)
[/TD]
[/TR]
[TR]
[TD] Transmission
[/TD]
[TD="colspan: 4"] 6-speed automatic transmission with Sequential SportShift, paddle shifters and Grade Logic Control
[/TD]
[/TR]
[TR]
[TD] Gear Ratios
[/TD]
[TD="colspan: 2"] Transmission gear ratios
[/TD]
[TD="colspan: 2"] Overall gear ratios
(including tire diameter)
[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]First
Second
Third
Fourth
Fifth
Sixth
Reverse
Final Drive
[/TD]
[TD]3.359:1
2.094:1
1.484:1
1.065:1
0.754:1
0.555:1
2.269:1
4.250:1
[/TD]
[TD]First
Second
Third
Fourth
Fifth
Sixth
Reverse
[/TD]
[TD]14.276
8.903
6.310
4.527
3.206
2.361
9.644
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 2"] CHASSIS
[/TD]
[/TR]
[TR]
[TD] Body Type
[/TD]
[TD] Steel unit body
[/TD]
[/TR]
[TR]
[TD] Front Suspension
[/TD]
[TD] Independent suspension with MacPherson struts
[/TD]
[/TR]
[TR]
[TD] Rear Suspension
[/TD]
[TD] Independent multi-link suspension
[/TD]
[/TR]
[TR]
[TD] Shock Absorbers
[/TD]
[TD] Gas-charged twin tube (front and rear)
[/TD]
[/TR]
[TR]
[TD] Stabilizer Bars
[/TD]
[TD] 22 mm diameter, solid (front); 19 mm diameter, solid (rear)
[/TD]
[/TR]
[TR]
[TD] Steering Type
[/TD]
[TD] Electric power steering, rack-and-pinion
[/TD]
[/TR]
[TR]
[TD] Steering Ratio
[/TD]
[TD] 15.0:1
[/TD]
[/TR]
[TR]
[TD] Steering Wheel Turns
[/TD]
[TD] 2.74 turns (lock-to-lock)
[/TD]
[/TR]
[TR]
[TD] Turning Circle
[/TD]
[TD] 39.0 feet (curb-to-curb)
[/TD]
[/TR]
[TR]
[TD] Wheels
[/TD]
[TD] 18x7.5-inch split 5-spoke cast-aluminum wheels
[/TD]
[/TR]
[TR]
[TD] Tires
[/TD]
[TD] Michelin Primacy MXM4 P235/60R18 all-season tires
[/TD]
[/TR]
[TR]
[TD] Braking System
[/TD]
[TD] 4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist
[/TD]
[/TR]
[TR]
[TD] Front Brakes
[/TD]
[TD] 12.3-inch (312 mm) diameter ventilated rotors
with single-piston cast-iron calipers
[/TD]
[/TR]
[TR]
[TD] Rear Brakes
[/TD]
[TD] 12.0-inch (305 mm) diameter solid rotors
[/TD]
[/TR]
[TR]
[TD] Stability Control
[/TD]
[TD] Vehicle Stability Assist™ (VSA®) with Traction Control System
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 6"] CAPACITIES
[/TD]
[/TR]
[TR]
[TD] Cooling System (total)
[/TD]
[TD="colspan: 5"] 2.3 gallons (8.6 liters)
[/TD]
[/TR]
[TR]
[TD]**
Fuel tank
[/TD]
[TD="colspan: 5"] 16 gallons (60.5 liters)
[/TD]
[/TR]
[TR]
[TD] Engine Oil
[/TD]
[TD="colspan: 5"] Change with oil filter – 7.0 quarts (6.6 liters)
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 6"] EXTERIOR DIMENSIONS
[/TD]
[/TR]
[TR]
[TD] Wheelbase
[/TD]
[TD] 105.7 in
[/TD]
[TD="colspan: 4"] (2685 mm)
[/TD]
[/TR]
[TR]
[TD] Track, front
[/TD]
[TD] 63.1 in
[/TD]
[TD="colspan: 4"] (1604 mm)
[/TD]
[/TR]
[TR]
[TD] Track, rear
[/TD]
[TD] 63.4 in
[/TD]
[TD="colspan: 4"] (1610 mm)
[/TD]
[/TR]
[TR]
[TD] Overall Length
[/TD]
[TD] 183.5 in
[/TD]
[TD="colspan: 4"] (4660 mm)
[/TD]
[/TR]
[TR]
[TD] Overall Width
[/TD]
[TD] 73.7 in
[/TD]
[TD="colspan: 4"] (1872 mm)
[/TD]
[/TR]
[TR]
[TD]Overall Height
[/TD]
[TD]66.1 in
[/TD]
[TD="colspan: 4"](1678 mm)
[/TD]
[/TR]
[TR]
[TD]Ground Clearance
Unladen
Fully Laden
[/TD]
[TD]
8.1 in
5.4 in
[/TD]
[TD="colspan: 4"]
(205 mm)
(137 mm)
[/TD]
[/TR]
[TR]
[TD]Angles of Incidence
[/TD]
[TD="colspan: 5"]Approach Angle – 17.2 degrees
Departure Angle – 22.0 degrees**
Breakover Angle – 18.1 degrees
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 6"]INTERIOR DIMENSIONS
[/TD]
[/TR]
[TR]
[TD]Front Seats
[/TD]
[TD="colspan: 2"]Head Room
Leg Room
Hip Room
Shoulder Room
[/TD]
[TD="colspan: 2"]38.7 in
42.0 in
55.7 in
58.6 in
[/TD]
[TD](983 mm)
(1068 mm)
(1415 mm)
(1490 mm)
[/TD]
[/TR]
[TR]
[TD]Second Row Seats
[/TD]
Leg Room
Hip Room
Shoulder Room
[/TD]
[TD="colspan: 2"]38.1 in
38.3 in
53.8 in
57.2 in
[/TD]
[TD](969 mm)
(973 mm)
(1367 mm)
(1454 mm)
[/TD]
[/TR]
[TR]
[TD]Interior Volumes
[/TD]
[TD="colspan: 2"]Passenger volume
Cargo area (rear seats down)
Cargo area (above floor area with rear seats down*)
Cargo area (rear seats up)
*SAE seating reference position
[/TD]
[TD="colspan: 3"]103.5 cubic feet
76.9 cubic feet
61.3 cubic feet
26.1 cubic feet
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 6"]FUEL ECONOMY
[/TD]
[/TR]
[TR]
[TD]EPA Fuel Mileage
(city/highway/combined)
[/TD]
[TD="colspan: 2"]20/28/23mpg* (2WD)
[/TD]
[TD="colspan: 3"]19/27/22 mpg* (AWD)
[/TD]
[/TR]
[TR]
[TD="colspan: 6"]*Based on 2015 EPA mileage estimates. Use for comparison purposes only. Do not compare to models before 2008.
Your actual mileage will vary depending on how you drive and maintain your vehicle.
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 6"] WEIGHTS
[/TD]
[/TR]
[TR]
[TD]Curb Weight
[/TD]
[TD="colspan: 3"]RDX (2WD)
RDX (2WD) w/ Tech Package
RDX (AWD)
RDX (AWD) w/ Tech Package
[/TD]
[TD="colspan: 2"]3,717 lbs (1686 kg)
3,732 lbs (1693 kg)
3,838 lbs (1741 kg)
3,852 lbs (1747 kg)
[/TD]
[/TR]
[TR]
[TD]Weight Distribution **(front/rear)
[/TD]
RDX (AWD)
[/TD]
[TD="colspan: 2"]2,231 lbs / 1,486 lbs
2,233 lbs / 1,499 lbs
2,277 lbs / 1,561 lbs
2,273 lbs / 1,579 lbs
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="bgcolor: #cccccc, colspan: 6"] TOWING
[/TD]
[/TR]
[TR]
[TD]Maximum Towing Capacity
[/TD]
[TD="colspan: 5"]1,500 lbs
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="width: 491, bgcolor: #cccccc, colspan: 2"] WARRANTY
[/TD]
[/TR]
[TR]
[TD="width: 176"]Vehicle
[/TD]
[TD="width: 315"]4-year / 50,000-mile limited warranty
[/TD]
[/TR]
[TR]
[TD="width: 176"]Powertrain
[/TD]
[TD="width: 315"]6-year / 70,000-mile limited warranty
[/TD]
[/TR]
[TR]
[TD="width: 176"]Outer Body Rust-Through
[/TD]
[TD="width: 315"]5-year / unlimited-mile limited warranty
[/TD]
[/TR]
[/TABLE]
More...
