What speakers do you have in your car?
Old Sep 25, 2003 | 02:50 PM
mkamber's Avatar
mkamber
Default What speakers do you have in your car?
I just want to know what speakers will fit in the 93 accord sedan.
What do you guys have in your cars???
I'm thinking of replacing the front door speakers and the rear deck speakers. How much space will have i have to work with?
I think the 93 accord Lx gets 6 1/2" front & rear right?
How do i replace the front speakers??? Can i take off the grill or is the door panel one piece? Any help will be gladly be appreciated. Thanks.
Old Sep 27, 2003 | 09:09 AM
InsertNameHere's Avatar
InsertNameHere
Insert Title Here
I thought the back were 6 x 9's?? im not sure.. i dont know the accord specs... check the web like Crutchfield.com
Old Sep 27, 2003 | 09:39 AM
Falkon's Avatar
Falkon
still alive
You should be able to take off the grille and then unscrew the speakers. Buy Infinity, you won't regret it.
Old Oct 3, 2003 | 01:09 PM
r2k2d2's Avatar
r2k2d2
hey i also have a 93 accord. the front and rear speakers are both 6.5" diameter, so get that size. this is how to install them:
the door panel and the grill is all one big piece, i.e. u cant take off just the grill, the entire door panel needs to be removed. if u look around the door panel there are these little colored plastic endcaps, if u remove them, the screws that hold the door panel in are revealed. once u remove all of those screws, put ur fingers around the inside of the door panel and tug fairly hard. the door panel is held in place with clips that go directly into the door. after you do that, the speaker will be revelaed. the rear speaker installation is even easier. stick ur head inside the trunk and u will see the bottom magnets of the stock speakers sitting there. there are 3 nuts that hold in the speakers down there. take those off and disconnect the wiring adn go to the back seats and pull the little speaker pods out. then just take out the rest of the screws adn replace the speakers. i have infinity speakers in the front and the back and i love them. they are crystal clear and have good bass output. i think u cant go wrong w. infinity speakers. i am also running a Polk MOMO 12" sub and RF amp. if you need any more help, contact me.
good luck.
