how come i can hear my car run through the radio
Old Aug 28, 2003 | 09:44 PM
ShastSmae's Avatar
ShastSmae
Default how come i can hear my car run through the radio
when i turn down the radio i can hear like an electronic whine noise and if i rev it up a little the sound goes up to. kinda annoying... 5channel amp+sub+speakers
Old Aug 28, 2003 | 09:58 PM
SiClone's Avatar
SiClone
X-Moder8er
Did you run the rca's and power wire on the same side??? That's the most common cause....
Old Aug 28, 2003 | 10:18 PM
ShastSmae's Avatar
ShastSmae
dont you kinda have to?
Old Aug 28, 2003 | 10:28 PM
BrownGuy's Avatar
BrownGuy
Think it might be a bad ground ...
Old Aug 28, 2003 | 10:30 PM
ShastSmae's Avatar
ShastSmae
ill tell you this when i turn the gain down for the rear speakers it goes away but i have to turn it all the way down . the front wine too i think i just was in the back so i did the rears
Old Aug 28, 2003 | 10:35 PM
Toyz51's Avatar
Toyz51
Make sure the ground for your amp is good, that is the most common problem. Next make sure that your rca's are of good quality and are at least 18" from the power cable through the car. Lastly, make sure that the battery connections are clean and not corroded. Also make sure the ground from the battery to the chassis is good as well as the grounds from the motor to the chassis.
Old Aug 28, 2003 | 10:40 PM
rcurley55's Avatar
rcurley55
99% that it's a ground in the system....give us more info on them (head, amp and any processors in between).
Old Aug 28, 2003 | 11:32 PM
ShastSmae's Avatar
ShastSmae
all monster cable. the rca cables are by the speaker wire for the interior speakers
Old Aug 28, 2003 | 11:50 PM
ShastSmae's Avatar
ShastSmae
check my profile this is whats in the car..
Old Aug 29, 2003 | 11:10 AM
rcurley55's Avatar
rcurley55
I wanted to know what size wires and where are they grounded to? Did you remove all of the paint before you grounded (down to bare metal) How did you ground the headunit, etc....
