Pioneer CD deck installation
Old Aug 28, 2003 | 09:35 PM
VtecRacer's Avatar
VtecRacer
Default Pioneer CD deck installation
I have a '98 Civic EX sedan, and might be getting a Pioneer DEH 6400 deck. Do I require another Harness for the new deck or can I use the factory harness..
And could I attach the OEM tape deck that's already in the car to the new deck and play tapes if needed?
Old Aug 28, 2003 | 10:03 PM
SiClone's Avatar
SiClone
X-Moder8er
Yes, you'll need an aftermarket harness that plugs into the car's wire plug. Then you splice and connect the wires from the Pioneer deck to the wires on the harness you bought. Go to Walmart and pick one up for $10 or less...
You'll also need a dash kit. Walmart should have that also. If they don't, see the auto parts manager and order whatever you need. They are direct seller's of Scoche products.
As for the oem add-on tape player. that cannot work with the new deck. Sorry....
Old Aug 28, 2003 | 10:47 PM
rcurley55's Avatar
rcurley55
One other thing to keep in mind...if your Canadian Honda comes with keyless entry, then you need to do some additional work, so go here for the details:
http://www.installdr.com/Graphics/Te...Select-PDF.gif
That doc will show you how to remove the factory head and take care of the keyless problem if it arises....
Old Aug 28, 2003 | 10:55 PM
VtecRacer's Avatar
VtecRacer
Thanks for the quick replies, very helpful info
I have an aftermarket alarm so that won't be a problem,
Old Sep 1, 2003 | 12:32 PM
VtecRacer's Avatar
VtecRacer
When I get the aftermarket harness it will just be a straight plug from Pioneer deck wire to into my factory harness?
Old Sep 1, 2003 | 06:56 PM
rcurley55's Avatar
rcurley55
the aftermarket harness goes between the car and the pioneer harness. You will need to solder them or use some solderless crimp terminals
