Integra alarm problem
Old Aug 6, 2003 | 02:15 PM
UncleBuddy's Avatar
UncleBuddy
Default Integra alarm problem
All of a sudden the factory installed alarm on my 97 Integra GS-R is sounding. I click the lock button on the remote and about 5-7 seconds later the alarm goes off.
I've checked the doors and hatch and they are all closed - besides it would chirp at me if one of them were ajar and I attempted to set the alarm.
Is this an electronics problem that I need to have checked by the dealer?
Thanks for any help!
Old Aug 6, 2003 | 03:01 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Sounds like a short within either the wiring or the alarm brain....:thinking:
Does the alarm "think" one of the doors isn't fully closed when you arm the system? Does it chirp at you- when you know the doors and trunk are shut fully?
If so, a shim on the door / trunk at the position of the appropriate switch might work as an interim fix.
Oh, is your GS-R a sedan or hatch? Only wondering because on my 97 LS 2dr, one of the door switches has already failed-and it may be a part of your problem. More doors, more chances for a switch failing.
Anywho... hope my input helps some..
Dave.
Old Aug 7, 2003 | 10:35 AM
UncleBuddy's Avatar
UncleBuddy
No it doesn't chirp at me. It locks and sets the alarm - then starts honking 5 seconds later.
My car is a hatchback.
I'm afraid it could be the alarm brain
Thanks for the response
Old Aug 7, 2003 | 11:26 PM
TheOtherDave™
Apathy Kills
Darn, so much for a cheap fix...
Hmm, check up on HAP Recycling, if you're on the west coast. A big time Honda/Acura recycler. Perhaps you can find a deal on another brain...:dunno:
Best of luck.
Old Aug 8, 2003 | 02:38 PM
UncleBuddy's Avatar
UncleBuddy
Thanks for the reply.
I'm on the East Coast - Wilmington Delaware - so I don't think I'll make the trek
Old Aug 20, 2003 | 07:58 PM
Red GSR's Avatar
Red GSR
Same thing happened to me, luckily it was just a blown fuse that caused the problem. Check your interior or trunk lights. Do they still work? If not, maybe you blew a fuse.
Old Sep 17, 2003 | 10:44 AM
toyman99's Avatar
toyman99
Take out the door switches (its probably a 10mm bolt)
all of them
disconnect the wires to them, see if it still sounds. If it doesnt, you have a bad switch. Then do it one by one.
