how do i mount my amp?
Old Jul 26, 2003 | 10:30 PM
Max Power's Avatar
Max Power
Buff Member
Default how do i mount my amp?
ok i bought a sub/box/amp combo and the amp was attached to the box, well the amp didnt work so i had to get a new one
now my amp is just laying on the trunk not attached to anything. i'm afraid having it shuffling around back there will be bad.
should i mount it to my seatbacks? and if so, how? how much would an audio shop charge to install it there? everythings wired up and the sub works, its just the amp isnt mounted
thanks for the help
Old Jul 27, 2003 | 01:30 AM
LjN_728's Avatar
LjN_728
Well you got a couple of options to mount the amp. You can mount it back on the enclosure/ box. That way, when you have to remove the box, everything goes with it. The other option is to mount it on the backseat. I would use simple lag screws. You can use the type of screws for wood work. A good 1 - 1 1/2" screw is good enough. G' luck!
Old Jul 27, 2003 | 09:27 AM
r2k2d2's Avatar
r2k2d2
just mount it on the back of the rear seats. thats how i have it and it works out great like that. just use about 1" wood type screwes and just drill the amp right into the back of the seat.
Old Jul 27, 2003 | 12:00 PM
Max Power's Avatar
Max Power
Buff Member
if i mount them to the backseats i'm afraid back seat passnegers will get poked :ugh:
Old Jul 27, 2003 | 12:49 PM
LjN_728's Avatar
LjN_728
uh..the backseats are at least 3" insulated. So if u use a 1 - 1 1/2" wood screw, it'd be fine. Don't worry man...we got it covered! :loco:
Old Jul 27, 2003 | 09:57 PM
Max Power's Avatar
Max Power
Buff Member
but when they sit on it it compresses some dont it??h:
Old Jul 28, 2003 | 12:53 PM
LjN_728's Avatar
LjN_728
Unless u got some crapped ass car with crapped ass seats, don't worry about it. 1" screws will do the trick. If you're so worried, forget it and mount it on the enclosure. We don't kno we're talking about, we just mounts amp on backseats cuz it looks kewl! :doh:
Old Jul 28, 2003 | 03:50 PM
Max Power's Avatar
Max Power
Buff Member
no offense man! im just concerened
Old Jul 28, 2003 | 03:55 PM
Kaspin's Avatar
Kaspin
1991 Prelude Si 4WS
I used some 1" self tapping screws to mount my PC on the back of my rear seat. Can't feel them from the front at all.
