2 Amp and Cap wiring Help
Old Jul 23, 2003 | 06:12 PM
r2k2d2's Avatar
r2k2d2
Default 2 Amp and Cap wiring Help
hey everyone. can someone show me/tell me how to wire 2 amps and a cap together? i assume i need to get a distribution block, but i am not 100% sure on how to do this. any paint or other diagrams you guys could post would be great. thanks.
Old Jul 23, 2003 | 09:12 PM
b00gers's Avatar
b00gers
to answer your question:
starting with the power wire at the battry terminal-
-fuse (size will depend on the amperge of all the amps)
-firewall
-trunk
-cap's + terminal
-fused d-block
-power wire to each amp
you can ground everything individually or at the same grounding point.
what two amps is the cap going to. the cap may be no use to the amp that is powering the mids and highs. they are for amps that power subwoofers.
Old Jul 27, 2003 | 07:45 PM
tarheelsoldier's Avatar
tarheelsoldier
most caps have two terminals on them. one has a plus beside it. main power goes to the cap,, and main ground to the cap. the plus is the main power and then it splits off to the amps. then the grounds go back to the cap and then u ground them from the cap. thats the way most caps are set up for (or at least thats the easy way)
Old Aug 10, 2003 | 01:23 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
so if I'm running two amps, one for mids/highs, the other for subs, how would I run it?
I'm thinking:
-fuse
-firewall
-trunk
-distribution block w/ fuses
-one wire connects to mid/high amp
-other wire goes to cap
-from cap to sub amp
Old Aug 10, 2003 | 08:55 PM
SiClone's Avatar
SiClone
X-Moder8er
Sounds good.
