Audio, Security, & Automotive LightingTroubleshoot wiring problems and get equipment suggestions all in one place. Now expanded to include Automotive Lighting
ill activate the keyless entry and everythings fine except for this constant CLICK CLICK CLICK CLICK CLICK CLICK like its opening/closing/opening/closing etc....it goes away after a minute. pretty annoying. what could it be? btw a month ago my siren died cause it was improperly grounded. any relation? thanks in advance
I'm going to guess that theres something that's grounded out when it shouldn't be. Did your car come with manual locks and then you added power door locks with keyless entry later on? If that's the case maybe the solenoid is going bad? :shrug:
it could be a weak ground to the brain - every time the ground resistance fluctuates, it activates or deactives the alarm. check under your dash for the brain and make sure it's grounded good.
