Remote door lock problem, pls help.
Old Jun 16, 2003 | 05:53 PM
forjake's Avatar
forjake
Default Remote door lock problem, pls help.
Hey all,
I've got a bit of a problem. Hopefully one of you might have an answer before I head over to Acura.
I've got remote door locks on an 99 Integra GSR with two remotes. One of the remotes used to sound the horn once for locking the car and twice for unlocking the door, together with the flash of the lights. The other one just flashed the lights without the horn. Now all of a sudden that controller decided to sound the horn too with each door lock and unlock. Now there has to be some way to set it back, or similar to that.
Any suggestions??
Please help, before I get really annoyed.
Cheers,
Jake
Old Jun 16, 2003 | 07:37 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
if your remotes have a trunk or option button, hold that down and press and hold the lock button for a couple seconds... you'll see the LED on the remote flash... then try the remote, the horn should not honk anymore...
If there is no trunk or option button, I forgot how to do it with those remotes.
Old Jun 17, 2003 | 01:24 PM
forjake's Avatar
forjake
Thanks,
I'll give that a try
Jake
Old Jun 26, 2003 | 06:44 PM
flappy188's Avatar
flappy188
O.G. SON!
hold the lock and unlock buttons in at the same time until the light on the remote flashes!!!
