Should I buy this amp
Old Jun 7, 2003 | 09:58 PM
carrwash13's Avatar
carrwash13
Default Should I buy this amp
Rockford Fosgate 500s Info link
Its going to be powering one 12" Polk momo. I was just wondering if it will work for me, cause I could get it for a good price ($165 shipped) and I don't have a ton to spend.
Old Jun 7, 2003 | 10:12 PM
red 97 lude's Avatar
red 97 lude
what is the voice coil config. on the sub? also what is the rms power handling?
Old Jun 7, 2003 | 10:17 PM
carrwash13's Avatar
carrwash13
All the stats are in the link.....500 W X 1 @ 4 Ohms Bridged RMS....1000 watts peak. I don't know a ton about amps, so I figured I'd just post a link instead of blindly putting down facts.
Old Jun 8, 2003 | 09:31 AM
smokedogg's Avatar
smokedogg
he asked for info on the SUB. that way we can figure out if that amp is right for that sub.
Old Jun 8, 2003 | 09:44 AM
carrwash13's Avatar
carrwash13
OOPS! My bad......Here's all the info:
Driver Complement
Woofer 1 - 12" Diameter (30.48cm)
Aluminum-clad Injection-molded Polymer cone with cast basket
Electrical
Overall Frequency Response 20Hz - 200Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 500 w
Power Handling (peak) 1000 w
Efficiency 87 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Enclosure Dimensions
Enclosure Type Sealed
Internal Volume 0.88 ft3
Overall Dimensions (including grill) 14-5/8" H x 14-5/8" W x 11-5/16" D
(37.15cm H x 37.15cm W x 28.73cm D)
Footprint Size 14-5/8" W x 11-5/16" D
(37.15cm W x 28.73cm D)
Old Jun 8, 2003 | 02:39 PM
red 97 lude
yup if the sub is a Single Voice Coil 4 ohm sub (which from the specs you gave it looks like), then that amp should be a very nice match. if it is a DVC 4 ohm , then you can get a 2 ohm load or an 8 ohm load, and i wouldnt run that amp at 2 ohm mono, so you would onle be getting maybe 250 watts rms to the sub. hope this helps :thumbup:
