UnderCar Neon
Old May 26, 2003 | 01:08 PM
DragonLord's Avatar
DragonLord
Default UnderCar Neon
Hi Guys First time Posting in here...
So Lets Try this..
Civic 97 SI
I just installed my Undercar neon but When I ower them on my radio is going all static...My connection are simple
transformer- first neon going around the 3 others coming back to the transformer and after that I have my switch battery to switch from switch to transformer and a ground from my switch to my car frame.. also a ground from transformer to my car frame
Also My Fuse doesn't last...
What do you Think
Old May 27, 2003 | 08:35 PM
acuradriva's Avatar
acuradriva
what fuse the fuse for the radio or the fuse for the car. it may be a bad ground on the transformer. or a short somewhere in the wiring.
Old May 28, 2003 | 01:07 PM
DragonLord's Avatar
DragonLord
Fuse of the transformer for the neon...
Radio is working great... when neon is not on
Only little bit of static when neon are on... but now event when I put them on no static hehe Fuse is dead
Checked my ground.. seems to be all good ...
Only have the one from the transformer and one from my switch...
But i think one of my neon might be defect the power doesn't go through correctly
I will go change it and see
Just call the guy and Just my luck its in Back Order
Old May 28, 2003 | 08:53 PM
PHiZ's Avatar
PHiZ
BOOST GOD
The concept of neon is that it requires AC current. That is why you have an inverter. Sounds to me like somewhere your AC source is not properly shielded, and it is bleeding into your radio circuitry.
I would consider running a dedicated return for it, if reccomended. Going forward, I would just tell people to use LEDs. Get the new ultra-intensity ones, they'll never break, run off of 12v DC very easily, and draw much less power...
-PHiZ
Old May 28, 2003 | 11:05 PM
acuradriva's Avatar
acuradriva
try just sticking a piece of wire from the transformer to a ground. Sometimes those case grounds don't work so great.
Old May 29, 2003 | 12:05 PM
DragonLord's Avatar
DragonLord
K thanks I'll have to do test with that
thanks guys
