make switch light up..
Old May 16, 2003 | 08:46 AM
epoxy's Avatar
epoxy
Regulator
Default make switch light up..
i wired up a switch to turn my subs on /off (cuts circuit to REM wire to shut subamp off), but i was wondering how i could make the switch light up. I was scared if i added a 12v wire to the switch the power would go into the REM wire and mess everything up.
Old May 17, 2003 | 07:11 AM
acuradriva's Avatar
acuradriva
You need a switch that has a light in it. if yours does than just Hook it up like the directions say. i think you just have to ground the switch.
Old May 19, 2003 | 03:12 PM
epoxy's Avatar
epoxy
Regulator
alright...made the 'off side' light up. How can i make it light up when i have the switch on? won't it blow a fuse or something?
Old May 21, 2003 | 01:07 PM
acuradriva's Avatar
acuradriva
off side light up? Is the light on in the switch all the time?
Old May 21, 2003 | 07:35 PM
epoxy's Avatar
epoxy
Regulator
no..only when it is off.
---------- (rough scematics of my switch)
1 2 3
1= ground
2= ecu to switch
3= switch to wireharness
basically, 1= ground, 2/3=accessory
when i turn it off (towards ground, the light turns on. When i turn it on to connect the ECU circuit the light is off.
Old May 26, 2003 | 12:13 PM
epoxy's Avatar
epoxy
Regulator
hm... acc/ground/acc blows the fuse (which i thought it would....but worth a try)
any ideas?
Old May 26, 2003 | 03:54 PM
95DXPhiladeph's Avatar
95DXPhiladeph
does your switch look like this...
if it does... then im not sure why it's not working...
i have mine wired exactly how it says on the side of the switch on the sticker...
ground, battery, fog lights....
let me know!
Old May 26, 2003 | 04:03 PM
epoxy's Avatar
epoxy
Regulator
hm..yes that is the switch
my setup is...
ground > ecu to switch > switch to ecu
it works when the circuit is cut (flipped towards ground)
Old May 26, 2003 | 05:09 PM
95DXPhiladeph
okay...
the switch has 3 circuits... one goes to the battery.... one goes to the ground.... one goes to what you're wiring...
there should be a sticker on the side of the switch telling you what circuit is what....
wire the ground, make sure it is wired TIGHT... your ground needs as much contact as possible... then put the other end into the SWITCH not what you're wiring....
then wire whatever it is to the switch....
then wire the switch to the battery... again... as much contact as possible... should be good!
Old May 27, 2003 | 09:30 AM
acuradriva's Avatar
acuradriva
my setup is...
ECU? i thought you were hooking this up on your remote wire???
