amps
Old Apr 1, 2003 | 08:11 PM
Phat8186's Avatar
Phat8186
Default amps
what do u guys think of this amp
PROFILE CA600 2 CHANNEL 600W AMP *NEW 2003
or
PROFILE 600SX Amp 3/2/1 CH 300W RMS BLOWOUT
I am on a tight buget so will this hit the knocks of what i need. I will have a kenwood Excelon HU 2002 model and either alpine type R 12's or Rockford series of subs 12's
Old Apr 1, 2003 | 08:21 PM
b00gers's Avatar
b00gers
ive never used a profile amp...but i have used the JBL bp600.1.
its a 600 watt mono amp at 1 or 2OHM. you can find it for under $200 easily on ebay.
Old Apr 1, 2003 | 08:24 PM
Phat8186's Avatar
Phat8186
will mono do two 4 ohm subs
Old Apr 1, 2003 | 08:33 PM
SiClone's Avatar
SiClone
X-Moder8er
Parallel the 2 4ohm (SVC's) subs to get a 2ohm load. The JBL maxes power at 2 ohms and is also stable at 1 ohm.
Old Apr 1, 2003 | 09:03 PM
b00gers's Avatar
b00gers
yes. if they are SVC 4OHM.
and the thing about the JBL amp. you dont have to wire them in any special way. there will be 2 sets of outputs. just wire each sub to each set of outputs, the amp will wire the rest to get a mono load.
Old Apr 1, 2003 | 09:58 PM
LjN_728's Avatar
LjN_728
The profile amp looks like an amp that could be found at a swamp meet, but crutchfields sells the line so it must mean it meets their standard. Which Type R sub do you have: The SWR-1221D or the 1241D? Difference between the two is that one's a 2 ohm and the other's a 4. Power handling are the same.
I don't wanna put down a amp just cuz i never heard of it before but yea it'd be best to do some research on it before you purchase, especially if you're going to buy it from ebay. Gotta watch out for refurbished items. Also the amp you linked could be an older generation model.
Old Apr 2, 2003 | 02:27 AM
Randy12vp's Avatar
Randy12vp
Definitely the JBL 600.1 as long as you don't have any loyalty to Profile.
Old Apr 5, 2003 | 09:02 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
I have a profile amp as a temp. sub amp until I get the JBL 600.1
its "400w" but the thing reads more like 100 to each sub. Definatly crappy with two 12s unless you want a more even sound (I'll admit the setup its perfect for rock). But I rather have phatter bass since I can control the sub output through the HU.
never buy profile :nono:
