Can someone explain this A/B vs. D class amps?
I'm looking for a amp to push one 12" woofer and wonder about the amp classes. Right now I'm running a Kicker ZR240 amp for my subs and a Phoenix Gold 500.4 amp for the highs. Does it make a great difference using a A/B or D class for the subs?
Thanks
Rob
Thanks
Rob
The great amp class debate...
If you were to use class D anywhere, it would be on a sub. Class D amps are more efficient than others, but you lose speed in the process (slew rate).
Like what Cheezthis said, Class D amps are super power efficient, except they can only really be used for low frequencies. Class A/B amps use more power, but can produce a better output for a much bigger frequency range and better sound quality.
That's what I've read from other sites but was confused about the sound quality issue between the two. I don't think I could really hear the difference between a high quality sub amp and a middle quality.
Some amps I have thinking about are Crossfire, JL Audio 300.2 and a Phoenix Gold Tantrum 500.2. Basically I'll be using them to push one Image Dynamics 12".
Rob
Rob
Originally posted by acuradriva
you won't really even notice the difference, unless you are an audiophile. just go class d they are cheaper and more efficent.
Class D amps cant reproduce a full frequency range like an A/B amp. Youre going to be missing out on a lot if you use a Class D on your mids and highs.
Just stick with Class D on your subs. It will work fine on an Image 12. I used to run Memphis ST1000Ds in several systems with Image Dynamics subs.
Originally posted by fujiwara takumi
bull**** that you buy from best try/short circuit city are all class d? is that why my mid/highs always used to blow?
which image dynamic sub are you pushing? the IDQ im guessing.
a cheap (in cost) amp i like to use is the JBL PowerValve Series. you can find it easily on ebay.
600.1 or 1200.1, <$200 or <$250 respectivly. although realize those amps are best used @2 or 1OHM. they are single channel amps btw.
