How big of an alternator?
Old Mar 26, 2003 | 07:14 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default How big of an alternator?
I want to get a new alternator in my 5th gen accord but am not sure how big i should go. Would a 150 amp alternator be good if i want to run a JBL 1200 x 1 amp? Thanks
Old Mar 26, 2003 | 07:15 PM
Matt86's Avatar
Matt86
vtec ownz j00
http://www.ikesound.com/Prod_Details.asp?Prod_Id=209
Link to the amp
fizzbob7's Avatar
fizzbob7
90 accord h22a
depending on what they offer, i'd go closer to 200......just in case
Old Mar 26, 2003 | 07:21 PM
Matt86's Avatar
Matt86
vtec ownz j00
anywhere online i could pick one up for pretty cheap? Thanks
Old Mar 26, 2003 | 08:01 PM
Teg711's Avatar
Teg711
Purge This...
175 + a phat amp + keep your car running! you'll be fine,
Old Mar 27, 2003 | 02:57 AM
Odysseus's Avatar
Odysseus
I would say that you don't need a new alternator unless or untill you are experiencing charging problems. Why replace a perfectly good alt if you don't have to. If you do have problems, you probably will not experience alternator failure without noticable signs beforehand. Additionally, if you are not playing your system for long periods of time or at all times when you drive, your stock alternator will probably hold up fine.
Additionally, if you are concerned, you may want to start by getting a deep cycle battery first.
However, if you insist on a new alternator, I would say to take the current from your stock alternator and add the currents from all the fuses from your audio equipment and any other power consuming add ons. This will give you more than enough juice to keep the battery charged.
One more thing. When I linked to your amp site, it seems to me that the power output stated was max output rather than rms. This may or may not be of concern to you.
Old Mar 27, 2003 | 09:24 AM
barto's Avatar
barto
You need an alternator for sure, don't be fooled unless you want your old one to die on you and then you are screwed. You can get a 130 Amp from Alterstart online http://www.4alterstart.com/highoutputalternators/ and they are only 200 bucks. Since a stock civic alternator is only 65 Amps 130 is a serious upgrade. Try that and let me know.
Old Mar 31, 2003 | 06:39 PM
d21x's Avatar
d21x
Ownz JOO
ebay has 125 amp alternators for like $125!!!
Old Apr 22, 2003 | 10:20 PM
Gusto222's Avatar
Gusto222
Man WHORE
check tha thread i just posted-- tah wholesale list..
also try sounddomain.com classifieds-- got mine $190 for 150amp alt - NIB
Old Apr 22, 2003 | 11:31 PM
MikeR's Avatar
MikeR
i would check into a bass capacitor. here again, if it aint broke dont fix it(alt), i work for a class 8 truck manufacturer and they come stock with 135 amp alt, but these trucks have everything from a tv, fridge, flourecent lighting, and not to mention all the chicken lights for the truck and trailer. i've got an teg in which i've murdered with an alpine 500 watt amp, and a 75x4 hu, not to mention fog lights and the like, and have had "0" problems. Unless there is a big power spike, i.e. head lights dimming when bass hits i wouldn't worry about it. my lights dim a little bit but i'm only running a 1/4 farad cap. and have been doing so for 5 years, if it's failed and your replacing any way and the higher output one is relatively the same price wise, why not but other wise i say no.
