Wiring Question
Old Mar 26, 2003 | 10:56 AM
asaspade421's Avatar
asaspade421
Default Wiring Question
i gotta 98 civic 4 dr...now that i have gotten the power wire thru the grommet on the drivers side...i need an idea on how where to situate the wire so its just not laying under my carpet for all to see...and plus that just looks plain old ugly...i just need some i deas on where to situate the wire so it will be hidden
Old Mar 30, 2003 | 04:23 AM
Randy12vp's Avatar
Randy12vp
Hide it under the sill panel.
Old Mar 30, 2003 | 05:40 PM
SiClone's Avatar
SiClone
X-Moder8er
Just try running it as near the edges as possible.
Don't you have a floor mat to cover up the carpet???
Old Mar 31, 2003 | 09:48 PM
LjN_728's Avatar
LjN_728
Yea why don't u run and hide the wire under the side railing or panel? Really easy to pop off and it does the job! Just be careful of not snapping the plugs when your pulling them out
Old Apr 8, 2003 | 05:28 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Default Re: Wiring Question
I have a pry tool that I use, but you can use a flat head and work the sill from the outside of the door. There should be a gap unser the plastic sill. You can stuff a two guage wire in there.
Old Apr 8, 2003 | 06:01 PM
b00gers's Avatar
b00gers
i have a pair of 4gauge running on the side of my integra. theres a slight bulge.
Old Apr 10, 2003 | 03:45 PM
Randy12vp's Avatar
Randy12vp
Hey Will...if you're ever bored and have some $$$ laying around, you can bag yourself some flat 4 gauge wire and see if that helps with the problem of the bulge. If of course you don't already have that run and I just wasted my time by writing this post.
Old Apr 10, 2003 | 09:02 PM
b00gers's Avatar
b00gers
yea ive seen the flat cables. they are nice. but the bulge doesnt bother me much. you cant really tell unless you are looking for a bulge :uh:
how much do they run BTW?
Old Apr 11, 2003 | 06:05 AM
Randy12vp's Avatar
Randy12vp
www.knukonceptz.com
Old Apr 23, 2003 | 12:08 AM
MikeR's Avatar
MikeR
you should be able to use the sill and then the piller between the doors and rear pillar, then rear sill and around the back seat, usually if you pull the corner of the rear seat up you can slide the wires through if the seats dont fold forward
