Component Systems
Old Mar 10, 2003 | 04:16 PM
LocaL raCer's Avatar
LocaL raCer
R.I.P. Kato-san
Default Component Systems
I was thinking about getting a 6.5 component system for my car. (93 accord) My question is, do you have to use an amp to power these? Will my stock Acura CL cd player be enough? If so, will the stock deck with this upgrade sound better? I hardly know anything about this kind of stuff, so any help at all will be appreciated. TIA.
Old Mar 10, 2003 | 04:45 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Re: Component Systems
No, you don't "have" to use an amp to run them, but it would sound many times better if you did. No, that deck won't be enough, it'll sound like garbage. some things to look out for first off is mounting depth, if you get anything over like 1 7/8" deep, you'll have to use a spacer so the magnet won't hit the window. What components to get depends on how much you want to spend on an amp to run them.
Old Mar 10, 2003 | 04:47 PM
LocaL raCer
R.I.P. Kato-san
i am looking to spend around $250. h:
Old Mar 10, 2003 | 06:07 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
You'd be better suited upgrading your deck instead of getting some good components to run off of it. You can have the best speakers in the world, but if you don't have the power to push them, they'll sound like garbage.
Old Mar 10, 2003 | 07:05 PM
Nelson's Avatar
Nelson
Administrator
You don't "have" to, but you would "want" to.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 10, 2003 | 07:27 PM
SiClone's Avatar
SiClone
X-Moder8er
You wouldn't do $250 components any justice with only deck power.
