Bridging(??) subs
Old Jan 19, 2003 | 05:33 PM
pSiRacer92's Avatar
pSiRacer92
Banned
Default Bridging(??) subs
My friend did this thing with my 2 subs where he hooked them together with one wire (I think it was positive to negative) and then took the remaining positive and negative and hooked them to the amp. My amp has 600 watts and he says this way it makes it so each sub gets 600 watts a piece. I don't see how this can work. Any help?
Old Jan 19, 2003 | 06:59 PM
Toxis's Avatar
Toxis
Car Audio Manb*tch
he wired them in Series. Which amp do you have? What subs do you have and what impedence are they? Oh and it's not the subs you bridge, it's the amp.
Old Jan 19, 2003 | 09:15 PM
LjN_728's Avatar
LjN_728
Yea make sure you check the specs of both your amp and subs before you attempt to bridge your amp. It's a very simple process to bridge them and most people do this. Just think of bridging a 2 channel amp as the same as a mono amp
Old Jan 20, 2003 | 06:30 AM
pSiRacer92's Avatar
pSiRacer92
Banned
well it's working but i was wondering how he can be putting 600 watts into both subs
Old Jan 20, 2003 | 11:50 AM
pomansouth's Avatar
pomansouth
does it sound any louder then it did before??
Old Jan 20, 2003 | 11:58 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
wirring the subs in series raises the impedance. Say if your subs are 4 ohms a piece... wirring a pair in series will give an 8 ohm load... effectively cutting the amplifier power in half. An 8 ohm load is higher than car amplifiers are rated at... this will let the amp run much cooler and draw less power, but like I said, the subs are only getting half the amps output power.
What impedance are the subs?
Old Jan 20, 2003 | 07:46 PM
b00gers's Avatar
b00gers
cant really answer the questions with the info provided.
what model amp and subs are you talking about...
Old Jan 23, 2003 | 10:17 PM
acuradriva's Avatar
acuradriva
If your amp on;y puts out 600 wattsx 1 each sub will get 300 watts if they are wired to match the impedece the amp puts out the 600 watts at.
Old Jan 26, 2003 | 08:24 PM
99accord520's Avatar
99accord520
how do you bridge.. explanition please
Old Jan 27, 2003 | 10:07 AM
pSiRacer92's Avatar
pSiRacer92
Banned
i already explained it kind of...
