stupid question
Old Jan 16, 2003 | 07:16 PM
99CivicHB's Avatar
99CivicHB
Default stupid question
just got my car back from the shop, and went home to install my new cd player. I didn't even test the old one before trying hte new one, so i don't know if it worked, but.... i connected the new one and ****ed up, accidentally left the battery connected, anyways, it didnt turn on. I freaked out, and disconnected everything again, disconnected battery, and tried to connect old one again (plug and play, since they are both pioneers) and nothing turns on either. I took out the fuse for "radio/clock" under the dash and it doens't look blown. What else could it be?
Old Jan 16, 2003 | 07:36 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
check the fuse under the hood, its a long shot but could be the prob. It was the prob when I did the same thingh:
Old Jan 16, 2003 | 08:27 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
check all the connections... if there is an inline fuse in the radio's wirring harness, check that...
but like he said, check the under-hood fuse as well... theres 2 seperate fuses that make the radio work.
Old Jan 17, 2003 | 09:19 AM
99CivicHB's Avatar
99CivicHB
well, the fuse under the hood was blown. Replaced it, and still no luck. I'm getting no power to my HU....is there anyway that i could have shorted out the wirring harness?
