Advice on a few things?
Old Mar 24, 2009 | 04:53 AM
gingas's Avatar
gingas
Default Advice on a few things?
I have a few things I wanted advice on. Never posted in this section b4.
here we go. It's a 91 Civic Si. Have a co worker who have a brand new alarm he"ll sell me for $50. This tech said he would do it but I need a diagram of my electrical system.
Is there anything on here I can print out/make copy. He didn't give me a price. Or buy alarm & go to a shop & let them install it. It's no famous name brand.
The other thing is I want a amp. Nothing expensive. As of now I have a Kenwood head unit ,4 6.5" speakers & a Infinity 12" sub. It sounds pretty good being powered by the radio but need it to hit a little harder. Anything good to run for $100.
Thanks
Old Mar 24, 2009 | 09:43 AM
b00gers's Avatar
b00gers
Unless the person who is installing your alarm is very good with his work, I would suggest shopping around for the alarm. You want to make sure it gets installed correctly and well. And with shopping around you can make sure you get all the options you want.
As for a $100 amp, you are pretty limited...but it would be much better than powering the amp off of the headunit...I am actually surprised you can do that. What model sub do you have?
Old Mar 25, 2009 | 06:42 PM
gingas's Avatar
gingas
This guy I use to work with several yrs ago installed my system. Yeah, I have a double din Kenwood cassete/cd player. A salesman gave it to me after a couple traded there Ford Explorer in. So, I took it. So my unit is running my mb quartz tweeters,4 -6.5" speakers & my 12" SUB IS A INFINITY. About amps I've seen a few a Jensen @Pepboys & then I found a Sony Xploid for like $98& 150. Would these be any good. The only amp I use to buy back in the day was Kenwood.
Yeah, I might skip the guy hooking up alarm & just find a shop for 1. Don't need nothing fancy.
Old Mar 26, 2009 | 08:04 AM
b00gers's Avatar
b00gers
Which model sub because Infinity makes a series of subs that require different amount of wattage. Stay away from Jensen.
Old May 30, 2009 | 03:10 PM
samabhi12's Avatar
samabhi12
I am new to this forum. I want to install an Alpine system. Pls give some feedback on it.
