alpine time correction
Old Dec 19, 2002 | 10:44 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
Default alpine time correction
how dows it work? do i only adjust the correction for the front left speakers and leave other 3 values at 0 or do i need to adjust it for the FL, FR, and RL but keep the RR value to 0?
Old Dec 19, 2002 | 10:55 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Re: alpine time correction
Set it to what sounds the best to you.
Old Dec 20, 2002 | 12:22 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
what is the correct way to set it tho? the manual is kinda confusing
Old Dec 20, 2002 | 04:20 PM
steveng's Avatar
steveng
i don't knwo what is the correct way to set it, but i just set the FL to 2.5 and FR 0 and leave the rest zero since i don't have any rear speakers except subs. try to play with them, as long as you feel you are in the middle of both left and right speakers, then it's a good setting. btw, i have 7995
Old Dec 20, 2002 | 05:19 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
the correct way is what sounds best to you, I wasn't being a smart*ss when I said that the first time. Everyones ears are different, you have to set it to your liking, not mine.
Old Dec 20, 2002 | 05:21 PM
McIntosh'd UA5's Avatar
McIntosh'd UA5
got VIP?
i think you have to do some math...
Old Dec 20, 2002 | 05:26 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
me? why do you say that?
Old Dec 21, 2002 | 11:38 AM
Toxis's Avatar
Toxis
Car Audio Manb*tch
Than why are you wrong? You adjust your EQ settings to your ear. Time correction is the speed of sound and making sure everything hits your ear at the same time. Do your ears hear things at different times than mine?
You follow the instructions and it walks you through it. You have to measure the distance from your head to each speaker then you put that distance into the equation they give you and that tells you where you need to set the levels at. Don't trust your ear, your ear has nothing to do with how fast sound travels, except from your ear to your brain. lol Whew...
Old Dec 22, 2002 | 08:06 AM
McIntosh'd UA5
got VIP?
not to you, and what i meant...
don't you have to measure the distance from the location of the driver's head to each of the cabin speakers...from here, you subtract the 3 closer speakers from the 1 farthest speaker...and then divide each value by the speed of sound to get the appropriate delay for that speaker???
doesn't sound to hard to me.
