Amp/speaker question
Old Nov 4, 2002 | 07:39 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Amp/speaker question
Just wondering if you guys think this amp................
Soundstream Reference 414S
would power these 6x9's
Polk Audio EX693A
and these components
Old Nov 4, 2002 | 08:07 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
:thumbup:
Old Nov 4, 2002 | 08:13 PM
b00gers's Avatar
b00gers
looks good. what are the specs.
Old Nov 4, 2002 | 09:38 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Here are the specs:
50x4 @ 4ohms stereo 12volts
75x4 @ 2ohms stereo 12volts
100x4 @ 1ohm stereo 12 volts
THD less than 0.1%
Signal-to-Noise >100 dB
Frequency Response 20 Hz to 20 kHz
Stereo Separation >90 dB
Damping >200
Input Sensitivity (Ref414s): 200mV - 5.OV (Ref414s)
Input Impedance 10K ohms
Crossover Output 340 mV output w/200 mV input (+4.5 dB)
Crossover Specifications(variable crossovers)
Low Pass: 30 - 120 Hz at 24 dB/octave
High Pass: 60 - 240 Hz at 12 dBloctave
Dimensions (Ref414s): 15.25” W x 2.25” H x 9.8”D
Polk Audio EXII 3 way 6x9's
RMS power 2-70 watts
Peak power 180 watts
frequency response 45-22,000Hz
Kenwood Dual Mag 6 1/2" component set
RMS power 2-90 watts
Peak Power 180 watts
sensitivity 92db
freq response 35Hz-35kHz
Old Nov 5, 2002 | 04:00 PM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
shut up
Old Nov 5, 2002 | 04:01 PM
moofoo's Avatar
moofoo
oh my fault they look good go for it
Old Nov 5, 2002 | 04:34 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
I know they look good jfwy. My question was if that amp will be enough to push those speakers, will it sound good, be enough power to make them sound good. I know Soundstream is very modest w/their amp ratings, and the specs you see for it are rms ratings. Think that amp has enough juice to push those speakers? Another good thing about that amp is that it can accept up to a 5volt input on the rca's which is perfect cause my Alpine deck has 3 sets of 4volt pre outs, one of which is a dedicated subwoofer pre out:thumbup:
Old Nov 6, 2002 | 10:15 AM
SiClone's Avatar
SiClone
X-Moder8er
The amp should power those speakers fine.... :thumbup:
Old Nov 6, 2002 | 04:57 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
I got the amp today, it's freaking huge Man, Soundstream makes good stuff, that amp is hella heavy, brand new w/warranty and my own personal repair dude
Old Nov 7, 2002 | 06:37 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
My check is going out today for my clarion eq/line driver, should be nice w/ my new soundstream reference 414S amp for my mids/highs:naughty: I can't wait to hook the sh*t up.
