thankyou very muchily, no worries about the wait
u did very well... :D thanks again |
can i have honda civic 2000 ex audio diagram
check the list, it is now added.
98 and 08 Accord V6 EX :o
no rush :o |
hey sorry about that, been busy with school and all.
Accord 07 4 cyl
Do you have the wire diagram for Accord 07 4 cyl alarm install? ( No Nav)
Thank you |
yeap check it up at the top.
I have a question, whenever I unlock/lock my doors, it makes this loud annoying sound and the windows roll down/up pretty slow... Is there a wire I can cut and fix the electric wire for the power window?
I believe someone installed the (aftermarket) keyless entry for the accord 96 because whenever I start the engine, it would lock the doors; has those functions. Thanks in advance. |
your aftermarket system has ignition controlled door unlock and lock. if you can take a pic or find out what type of system you have, i can show u the wire that will need to be cut so the power windows will not roll up or down when you lock/unlock.
Ah, no. I think whoever installed that function hooked the electric wire to the window power? 'cause the windows go down really slow….
every time i turn on/off the engine, it has the alarm function on the door locks (lock or unlock it), but the noise is loud and annoying. is there a wire or something I can disconnect so the sound goes off? |
