electrical problems
Old Oct 15, 2002 | 10:51 PM
R81integ's Avatar
R81integ
Default electrical problems
1 when i turn on my highbeams, all the lights on the right side go dim.
2 when i turn on the fog lamps same thing happens.
3 dome light and console lights stopped working.
4 radio won't work or the cigarette lighter.
92 integra ls all this ish started after someone ganked my radio and woofers. can i get some help?
Old Oct 16, 2002 | 05:47 AM
Bass Mechanic's Avatar
Bass Mechanic
Default Re: electrical problems
i think the dome light and dash lights is the result of shorted wires in the dash where the radio was, you have a blown fuse or 2.
as for the lights on 1 side? which lights are you talking about exactly?
Old Oct 16, 2002 | 02:39 PM
R81integ's Avatar
R81integ
the right headlight and bottom turn signal.
Old Oct 16, 2002 | 02:52 PM
Bass Mechanic
if i were to guess i would say a bad ground at the headlight. what is happening is the turn signal and high beam are finding a ground through the low beam filiment and returning to ground through it.
sounds complicated i know but look under your car. try removing thoes lights affected. possibly the theives cut some wires under your car. for what reason i dont know unless they figured they could disable the alarm if they thought it was equipped.
best way to find the problem is look visually. then using a meter or test light test the curcuts with the lights on at each light. if you find a ground wire with power on it that would be the bad one.
good luck
Old Oct 16, 2002 | 05:07 PM
R81integ's Avatar
R81integ
thanx
