Infinity BassLink
Old Oct 15, 2002 | 06:51 AM
albee's Avatar
albee
Default Infinity BassLink
Has anyone got an Infinity BassLink? Opinion?
Old Oct 15, 2002 | 07:59 AM
albee's Avatar
albee
...another question or two. If the rear shelf speakers are only for 'fill', would it make sense to install a smaller speaker (4x6,5x7?) in the 6x9 opening in my Accord? Would the gap allow enough bass to get through from a sub in the trunk, or would this kind of thing just screw up the sound?
Old Oct 15, 2002 | 08:34 AM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
are you running all 4 speakers from a stock unit?
My friend has the basslink in his 94 LX, major concern is placement of the thing. It really didnt give that great of a low end punch... even with it's integrated 200watt amp.
And about your idea of using a smaller speaker.. you'll need an adapter to use a smaller speaker... I dont see where the space/gaps would come from the adapter is supposed to fill in the bigger hole make fit for a 5x7 or whatever...
Rear speakers are not just for fill IMO, they give music spatial ambiance. But the consensus around here and I agree is to have components up front, rears the same in the back.
Old Oct 15, 2002 | 09:42 AM
albee's Avatar
albee
I have the following on order to replace the stock setup...
Alpine 7894 deck
Infinity Kappa components for the front
Instead of a solid plate to mount smaller speakers in the 6x9 opening, I was thinking along the lines of using standoffs from the stock screw holes to the (small) speaker mounts. This would leave a gap between the cutout and the speaker of approximately 1". But I'm wondering if that would mess up the speaker's response - maybe a small enclosure would have to be built. Apparently some people have cut holes in their rear decks to get the bass out of the trunk.
Old Oct 15, 2002 | 03:03 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
A basslink is a great option for just adding some low end. If you are not a bass-head and just want a little extra punch to the stereo, go for it.
With the rear speakers... the only way they will sound good is if the front and rear of the speaker are totally seperated... when the sound from the rear of the speaker meets the sound from the front of the speaker, some frequencies start to cancel each other out... making the speaker sound terrible.
The basslink is powerful enough to penetrate the rear seat, without the need for extra "ports" to let the sound into the car.
If you are really concerned about it, you may want to try something a little more powerful, like a seperate subwoofer and amp combination.
Old Oct 15, 2002 | 04:48 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
I don't think the little bit of gain in bass from the Basslink is not worth losing out the midbass that the 6x9's can provide over 4x6's
Old Oct 16, 2002 | 06:55 AM
albee's Avatar
albee
[QUOTE]Originally posted by SumAccordGuy94
[B]A basslink is a great option for just adding some low end. If you are not a bass-head and just want a little extra punch to the stereo, go for it.
Yup, that's what I'm looking for - just to add some bottom end. I also want to use the trunk for regular trunk stuff. I'll order in some new 6x9 rears - so far I'm going Infinity Kappa components for the front, and now the BassLink. So what do you think about Infinitys for the rear?
Old Oct 16, 2002 | 08:16 AM
SumAccordGuy94
Older Honda Fanatic
Go for the infinity 6x9's... the bass link is also great cause it barely takes up any space, and it has a grille integrated, so no worry about hitting the driver with anything in the trunk. Its even light-weight, for the speed freaks!
Old Nov 30, 2002 | 03:39 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The BassLink is absolutely awsome.
Prior to buying my LS, I ran mine with an "Xplod" deck and Infinity 5-1/4" w/ Denon tweets.
I like a tighter, less boomy bassline and the BassLink totally delivers.
Nice size, reasonable weight too.
Get one.
Old Dec 2, 2002 | 09:35 AM
albee's Avatar
albee
I'm in the middle of my installation right now. I've got the interior taken apart in my 95 Accord EX V6.
This is what's going in:
Alpine 7894
Alpine MRV-F340
Alpine CHA-S634
Infinity Kappa 60.5CS
Infinity Kappa 692.5
Infinity Basslink
Does anybody know where the factory crossovers for the front woofer/tweeters are hidden? Without ripping the entire dash apart, I can't find anything that looks like a crossover.
