How can I boost my FM radio reception?
Old Oct 15, 2002 | 05:48 AM
T-RO's Avatar
T-RO
Default How can I boost my FM radio reception?
I'm using a stock Civic radio with a stock antenna (which is bent). There are some local stations that I can recieve in all my other cars but not in my Civic, or they come in really bad. Can I do something about this?
Thanks
Old Oct 15, 2002 | 10:27 AM
smokedogg's Avatar
smokedogg
good question....i can get hella stations w/ my home stereo system, but not nearly as many in the car even when im in the driveway.....
Old Oct 15, 2002 | 03:00 PM
LjN_728's Avatar
LjN_728
yea just go to ur local radio shack or whatever you got and buy a power antenna. it's not the type that goes up and down. it'll do the job
Old Oct 17, 2002 | 03:12 AM
Blckaccord98's Avatar
Blckaccord98
It's most likely the bent antenna that you need to replace. If you ever took out the factory radio before you might want to check to see if the antenna is plugged all the way in. Sometimes it gets loose and causes radios to loose reception.
