Battery Drain
Old Aug 25, 2007 | 07:23 PM
trades707's Avatar
trades707
Default Battery Drain
Hi, I'm working on a 91 Accord that keeps getting dead battery. I'm measuring about 30 ohms with the battery disconnected from the plus battery wire to ground. When I unplug the 80 amp alternator fuse, the low resistance goes away. However, when I disconnect the alternator at the fuse panel, the low resistance stays. I've pulled all other fuses and relays with no effect. Any ideas? Thanks Jim
