10" 's or 12"'s
Old Oct 13, 2002 | 12:51 PM
NewWorld's Avatar
NewWorld
Default 10" 's or 12"'s
I want to get some subs and not sure whether to go with 10"s or 12"s. I'm not looking to spend alot of money so I found a good deal on two 300-watt LightningAudio 10"s with LightningAudio 700-watt amp, and a box for $200 installed. They also have the same deal but with two 400-watt 12"s subs for $20 dollars more. Should I go with the 2 10"s or the two 12"s. And I know LightningAudio isn't great so I don't need anyones comment on that. Just 10"s or 12"s. Thanks
Old Oct 13, 2002 | 02:44 PM
b00gers's Avatar
b00gers
ive always liked a pair of 12s. never had a pair of 10s in my can personally. not that i never would, it just so happens i never have.
its really up to your ears man.
Old Oct 13, 2002 | 06:39 PM
seth90dx's Avatar
seth90dx
Well, the way I see it. If the 10" inch speakers are 300 watts each, and the 12" are 400 each, and the amp is 700 watts. its not a tuff decision! GO WITH THE 12"s DUDE!
Old Oct 14, 2002 | 12:09 PM
dlh1999's Avatar
dlh1999
Runs with scissors.
Consider both sides:
With 10's you'll have tighter, probably cleaner bass and the box will more than likely take up less space. However, you may feel like you want more bass later on.
With 12's you'll have deeper, more powerful bass (compared to an equivalent model as the 10's). They'll also be more than enough assuming you put the right power to them, and you can always turn down the gains on your amp if it's too much. However, the box will be a bit bigger and take up more room.
It's pretty much up to you...what kind of bass will you be looking for? I've always thought 10's were plenty, but I've also always preferred 12's just because I'm weird like that...
Old Oct 14, 2002 | 04:34 PM
Gusto222's Avatar
Gusto222
Man WHORE
i HAD... 2-10z & 1-12" all sealed... -- now i have 2-12z vented!
Old Oct 14, 2002 | 08:24 PM
NewWorld's Avatar
NewWorld
Thanks for the opinions!! I went in and tried them both out. I've decided to go with the 12"s, which I'm getting installed tomorrow... Thanks again.
Old Oct 14, 2002 | 11:03 PM
steveng's Avatar
steveng
i have 2 12"...and all i can say is..wow they are fawking loud at full potential. i set the input level(gain) on the amp to -4db just so i can hear the music better. at 0db which is the max. gain level, all my windows will rattle like biatch
Old Oct 17, 2002 | 04:59 PM
NewWorld's Avatar
NewWorld
Yup.. Thnx everone for the Info... I just got the 2 12''s installed and they sound awesome. Thanks again.
Old Oct 17, 2002 | 07:00 PM
SiClone's Avatar
SiClone
X-Moder8er
Good for you!!!:thumbup:
Old Oct 18, 2002 | 01:06 PM
08SnakeEyes08's Avatar
08SnakeEyes08
Vince Tran....
damn.... i was late.... 1 12" ported with 4 cubic feet...... lol... 1 dd9512... ........ with dual 1 ohm coils.... with a dei 1100 on each.... WOW.... THATS LOUD........ i can see 150 ++ dbs......
