Amp question
Old Jun 5, 2007 | 01:45 PM
russianpsyco's Avatar
russianpsyco
Default Amp question
I just hooked up an amp in my car but for some reason its not working. I hooked up the power, remote and ground the way it should be but for some reason when I turn on the car, the power light on the amp goes on but then fades out.
I think its not getting enough power but could it be anythin else that can cause this?
Thanks
Old Jun 5, 2007 | 02:45 PM
94civicEX's Avatar
94civicEX
I got worms.
Is it a new amp?
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 5, 2007 | 04:08 PM
russianpsyco
no this amp is used but before i took it out of my bros car i tested it and it worked great.
Old Jun 6, 2007 | 05:26 AM
akeura369's Avatar
akeura369
theres a couple possibilities - 1. your power wire is not the correct gauge 2. your ground is loose/bad connection 3. either your battery/alternator is on its way out and cannot handle an amp on top of everything
what i would do is check your battery and remote wire with a multi-meter and make sure your getting enough power, if your are then check the wires and try a bigger power wire, and make sure the ground is tight
