Overheating Amp
Old May 22, 2007 | 05:37 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Originally Posted by totalimmortal
Get the model number and research it. Why does it feel like I have to hold some peoples hand the entire time...
well, he did buy audiobahn.....
Old May 22, 2007 | 05:05 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
^^^True statement. Either way, it would occur to me as common sense to find a model # of some sort and research.
Old May 24, 2007 | 04:44 AM
InfoAudio01's Avatar
InfoAudio01
in an audio setup, you choose your a SVC or DVC depending on the amp you are pairing the sub too. always use both coils on a dvc, if you only use one it will only receive half the power to the sub and it throws off all teile-small parameters when matching the sub to the proper encloser.
if your audiobahn subs are matched right for your amp then try this...check your ground from your capacitor/amp to ensure it isnt loose at the frame where it is bolted to the chassis and the paint is removed to bare metal. also the ground wire should be 4 ga. or larger if your power wire is 4ga.
also use a meter to test each sub for its proper impedance to ensure they are not blown, causing the amp to overheat.
Old May 25, 2007 | 06:01 PM
sqsi's Avatar
sqsi
Where do you have the Gain on the Amp set? this could be the issue as well.
