Farad capacitor question
Old Apr 27, 2007 | 07:21 AM
MRSN3AKS's Avatar
MRSN3AKS
Default Farad capacitor question
How many farads do I need for 2400 watt amp? I have a Audiopipe 1.0 farad capacitor. Not enough tho right?What is it 1.0 farad for every 1000 watts?
Old Apr 27, 2007 | 07:35 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Correct. Do you have a dimming problem as it stands??
Old Apr 27, 2007 | 07:42 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
What kinda car do you have, what's your alternator output (AMPS)?
To calculate the current draw of an amplifier, multiply the number of channels by the RMS watts per channel (a 2 channel amp rated at 2000 watts RMS per channel would be 4000 watts). Double it to account for amplifier inefficiency (4000 watts X 2 = 8000 watts), then divide by the average output voltage of an alternator, 13.8 volts (8000 divided by 13.8 = 579 amps). Since the average music signal requires about 1/3rd of the average power in a test tone, divide by 3 (579 amps divided by 3 = 193 amps).
This is an average approximation of current draw and can go higher. So I would gather between 194 and 289 amperes for this example.
The alternator of a:
compact car is about 35 amps
mid-sized car is about 65-75 amps
SUV is about 145 amps
Calculate 40% of the amperes of the alternator you have now. This is the average current the car uses when running. Add this number to the approximate average current draw of the amps, and you will come up with the actual size of alternator you need.
If the number you come up with is the same as what your alternator supplies, you need to take no action.
So in other words, calculate to see if the amp is using more energy than the alternator can supply. If it is then use a cap, if not then your car should be fine.
Old Apr 27, 2007 | 07:45 AM
MRSN3AKS's Avatar
MRSN3AKS
I havent installed anything yet. Maybe this weekend. 01 Accord Ex.
So I shouldnt put the 1.0 Farad up with the 2400 2 channel amp huh?
Old Apr 27, 2007 | 07:50 AM
v6_accord_jerz
Stupid Power Ball
So your alternator puts out 80 amps.
Old May 25, 2007 | 06:13 PM
sqsi's Avatar
sqsi
Capacitors are not going to help your charging system, they only help with spikes in current demand. You are better of getting a HO Alternator, a Kinetik Battery, and upgrading your power and ground cables. then no cap needed. I run 2200 watts with no capacitor.
File Type: jpg
Old May 25, 2007 | 10:07 PM
b00gers's Avatar
b00gers
Lets be more clear, is that 2400 watts RMS or one of those crazy max ratings?
Old May 26, 2007 | 05:18 AM
sqsi's Avatar
sqsi
RMS watts, I run all Alpine and they don't use those B.S Max Power Ratings
File Type: jpg
Old May 27, 2007 | 03:36 AM
Thi3v3z's Avatar
Thi3v3z
Well you would be correct about the 1000rms for 1 farad. But sqsi stated, capacitors wont fix your problem, they are more or less a bandaid on a stab wound... A cheaper way would be to upgrade the big three, and run a 2nd battery. I am curious however what are you running that takes 2400 watts?
