JVC KD XL10 problems
Old Jan 1, 2007 | 01:08 PM
Rebelwork's Avatar
Rebelwork
senile
Default JVC KD XL10 problems
I've wired the receiver to the factory harness , but wont fire up. Took the yellow wire from the wiring harness and ran it direct to the battery and unit will power up only for a few moments. There was a security system installed but I have disconnected it.
Any ideals?
Old Jan 1, 2007 | 03:05 PM
b00gers's Avatar
b00gers
What happens after it powers up for a few moments?
Old Jan 1, 2007 | 03:11 PM
Rebelwork's Avatar
Rebelwork
senile
CD door opens then shuts off again. A few times the keyboard will come out then shut down. Sometimes I get power surges then nothing.
I pulled the unit from my truck and it worked fine. Trying to figure out if the security system that was installed effects the unit. Right now Im charging the car battery as I havent swapped motors yet....Jack
Old Jan 1, 2007 | 05:00 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
It may be toast, I've had one.
Old Jan 1, 2007 | 05:04 PM
Rebelwork's Avatar
Rebelwork
senile
Not impossible,but I find it hard to believe as I stored it back into its original box and has been sitting in the cabinet.
Old Jan 1, 2007 | 05:06 PM
totalimmortal
MalleusMaleficarum
Hmmmm, Did you use a wire harness adapter??
Old Jan 1, 2007 | 05:17 PM
Rebelwork's Avatar
Rebelwork
senile
Yes.. One was used with the Alpine in the 93 civic. I just reused it in the 95 with the JVC....Jac
Old Jan 1, 2007 | 05:18 PM
totalimmortal
MalleusMaleficarum
So you cut the factory plug??
Old Jan 1, 2007 | 05:26 PM
Rebelwork's Avatar
Rebelwork
senile
No, after market plu in...
File Type: jpg
Old Jan 24, 2007 | 07:11 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
how old is the unit, and how long has it been sitting idle?
