Auto mute wire on radio
Old Nov 2, 2006 | 07:16 AM
kevyt's Avatar
kevyt
Default Auto mute wire on radio
I am trying to install something that has a wire that is suppose to connect to the auto mute wire on the radio. I can't find the answer in my Haynes manual. Does anyone know if a 96 GSR has the wire or if there is a way to mute the radio when something else comes on?
Thanks,
Kevin
Old Nov 2, 2006 | 09:41 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The auto mute wire is generally used when there is a factory-equipped in-car cellular phone.
Since the OEM Integra radio did not have an auto-mute feature, using the auto-mute feature on an aftermarket headunit will require additional wiring on your end.
Lastly, moved to Audio & Security... you'll be in good hands.
Old Nov 3, 2006 | 05:20 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
No.
Old Nov 7, 2006 | 02:02 PM
supra88's Avatar
supra88
there is a mute only on the bose system but the radio needs to be open and 2 wires need to be solder,
outside you need a relay to interrup the cable loop
