How to change number of ohm's?
Old Sep 30, 2002 | 10:23 AM
xbladr's Avatar
xbladr
Default How to change number of ohm's?
Hey i got 2 Lightning Audio 12" subs and a pioneer 300 watt max amp. it says the subs are 4 ohms in the booklet is there anyway to change this? like to 2 ohms or watever? and how exactly does this work thanks
Old Sep 30, 2002 | 10:40 AM
b00gers's Avatar
b00gers
you cant change it....the only way i can think of "changing" is if you have a sub that has 2 voicecoils, a DVC.
then by wiring the sub in paralle or series, you "change" the impedance (ohm).
Old Sep 30, 2002 | 04:39 PM
seth90dx's Avatar
seth90dx
LOL! what 4 ohms isnt loud enough or somethin? Mine are runnin at 8
Old Sep 30, 2002 | 05:43 PM
smokedogg's Avatar
smokedogg
wow, mine are running at about 1
Old Sep 30, 2002 | 07:17 PM
b00gers's Avatar
b00gers
what?
Old Oct 1, 2002 | 08:18 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Why are your subs running at 8 ohms??
Old Oct 1, 2002 | 08:37 AM
b18cya's Avatar
b18cya
uh, no u suck
if you have two 4 ohm subs, you can wire them in parallel, & have a total load of 2 ohms. this will maximize the output of the amp if it is stable at 2 ohms.
Old Oct 1, 2002 | 09:32 AM
08SnakeEyes08's Avatar
08SnakeEyes08
Vince Tran....
what if his amp puts out 600 watts at 2 ohms and his subs are 500 peak??
if u got 2 250watts rms subs.. and whats ur amp?? go with 4 ohms to be sure. 4ohms never hurt ur subs. i'd rather under power then over power subs unless ur at a competition.
but in ur case ur 300 watt amp is good enough. plus, at 2 ohms.. ur amp might be more distorted and sound like crap, because ur amp puts out crap instead of real power.
Old Oct 5, 2002 | 05:42 PM
PnX-R's Avatar
PnX-R
Well let's see.. I don't know much about speakers. But I do know that to reduce the resistance in a parallel circuit, you have to add loads. Or in your case, more speakers..
