Best Subs for amp
Old Sep 6, 2006 | 11:05 AM
azn1028's Avatar
azn1028
Default Best Subs for amp
amp specs:
250W x 2-Ch @ 4-Ohms or
500W x 2-Ch @ 2-Ohms or
1000W x 1-Ch @ 4-Ohms
it was given to me and i want to match up with the best setup.
i would like 2-12's or 1 12.. i would like a 12.
my old setup was a JL 15 w0 with a bridged small crossfire 50.2 amp. 180x1 watt bridged and it hit pretty hard. hoping for a harder hitting setup.
thanks.. been a while since ive been here
Old Sep 6, 2006 | 12:08 PM
FrozenAcid's Avatar
FrozenAcid
are you really set on getting 12s? you could probably find a good set of 10s and will be more than able to handle 500w each. plus they could take up less space... which is a plus.
Old Sep 21, 2006 | 07:23 PM
mr22na's Avatar
mr22na
Miss It.
get two 10 inch ALPINE TYPE R
Old Sep 21, 2006 | 08:36 PM
dleccord's Avatar
dleccord
no get 1 ten inch type r...dual 2 ohms.
Old Sep 21, 2006 | 09:40 PM
b00gers's Avatar
b00gers
WIth so much more power, itll be much louder. If you have 1000 watts to play around with, I would go with a nice set of 12s. Your wallet limits you. How much did you want to spend on subs?
Old Sep 22, 2006 | 08:49 AM
burnrubber's Avatar
burnrubber
Nucking Futs
if you want one sub go with a Alpine type X 12, that is if that amp will put out 1000rms at a 4ohm load, if so make sure you get a DVC 2ohm a coil and wire in a series
Old Sep 22, 2006 | 10:06 AM
mr22na's Avatar
mr22na
Miss It.
thats like 600$ for just the sub...plus the box would have to pretty large for the correct airspace...if you got the funds go for it...that would be an awsome set-up...
Old Sep 22, 2006 | 11:36 AM
dleccord's Avatar
dleccord
http://cgi.ebay.com/ALPINE-SWX-1242D...QQcmdZViewItem ?
but remember, he said he wanted a hard hitting sub(spl maybe?) this sub is not an spl sub. either way, we still dont know cause he's not clear.
