mounting amp on box
Old Jul 12, 2006 | 08:47 AM
flyromeo3's Avatar
flyromeo3
Default mounting amp on box
is it safe to mount the amp on the subwoofer enclosure?
Certainly I plan on placing a small board on the box and then screwing the amp onto that. Maybe put rubber spacers in between to limit the vibration.
Is it ok to do it?
Old Jul 12, 2006 | 09:16 AM
b00gers's Avatar
b00gers
I have no problem doing it. If it is a decelty build box and a decently built amp, I cant imagine any problems. If you have a huge box without braces made of .50" particle board...then I the vibrations and flexing from the box might damage the amp in the long run :dunno:
Old Jul 12, 2006 | 03:02 PM
mishqua's Avatar
mishqua
Make sure you mount it on the side, as a big box with the amp mounted on top can overheat easy. Reason being its to close to the lid of the trunk, you will have the sun beating down on it asid from the heat being generated from the amp.
Old Jul 12, 2006 | 05:50 PM
angelgabe's Avatar
angelgabe
Do-It-Yourselfer
I wouldn't recomend it simply cause if you ever- for any reason need to throw something large into your trunk, removal of the subwoofers would be alot more complicated. Also, if you don't bolt down your sub box all the movement will loosten your ground connection. I know drilling holes in your car might sound scary, but its probably your best bet.
Old Jul 12, 2006 | 06:14 PM
Nors's Avatar
Nors
倍力恋
And if someone happens to break into your car, they get everything in one grab. Which is never good.
Old Jul 12, 2006 | 11:53 PM
foefinga's Avatar
foefinga
"And if someone happens to break into your car, they get everything in one grab. Which is never good."
i agree with that. i have my amp mounted to my back seat
Old Jul 19, 2006 | 05:16 PM
HONDA_driven's Avatar
HONDA_driven
got vtec?
Default Yes their can be a FIRE HAZARD!!!!
Yes you can mount the amp to the top or the side of your prefabricated sub enclosure. BUT... make sure your box is securely mounted to the trunk flor!!!!! if the box shifts and the 12volt primary power supply comes out of the amp and touches metal in the trunk it will short and arc, thus making your trunk a fire hazard!
Old Jul 20, 2006 | 05:51 AM
dleccord's Avatar
dleccord
thats why your box should weigh 110+ pounds and be as big as fvck use some hex screws on the amps as well
